i think im going to go for it ..GS owners let me see your systems
#92
Cast aluminum basket
Stone Gray finish w/ Diamond cut edge
Cloth laminated paper cone w/MD6 coating
Hi-Arc, High Excursion Surround
Chrome Plated Back plate
Low carbon top & pole piece
1-piece rubber gasket
Triple Stacked Magnet Structure
Black Progressive Roll CONEX spider
Woven tinsel leads
Vented & extended pole piece
Gold binding posts
Dual 4 Layer 1 ohm voice coil
BAEISV hybrid voice coil former
Rubber magnet cover
Wood packing crate w/chrome hardware
* Tarantula 10"
* Frequency Response 28 Hz-1.8 KHz
* 160 Oz. Magnet
* 3" Voice Coil
* Sensitivity 87 dB
* XMAX .63"
* 800 Watts RMS
* Mounting Depth 5.75"
* Recommended Enclosure 1.7 CuFt Ported
#98
Originally Posted by engin_ear
Looks to me just pretty much plexiglas and mirrors and blue neon, cost shouldn't be too outrageous. You can use the amps and speakers of your choice, Spidey.
ok do i need this J
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=5780317474
#99
Everything in Moderation
J-Spide, if you're running more than one amp, it's a nice choice to distribute power and ground, and it apparently has a voltage monitor or two. Looks pretty well made too. Wire gauge accepted = 4 (good), also accepts up to 100A mini-ANL fuses (good).
If you're just doing an amp for subs or a single 5-channel amp, you won't need it cause you can use individual parts, but you could still use it for show and only use part of it. If you're doing a F/R amp plus sub amp, you'll need a distribution block & fuseholders. Looks pretty sweet to me for show, if it were me and I was doing the Soundstream thing, I'd put it in just for show.........
#101
thanks for all the help J
i found this deal let me know what you think
I have two SPLX 15" Subs, soundstream 1600/2 tarantula amp, 800/4 soundstream tarantula 4 channel amp, and 2 sets of subwoofer grills. I sold the digital caps to a buddy of mine so you will need at least one capacitor, I had ask xxxxxxbefore, I was told that is what the system is worth but I have found out its not! I am asking xxxxxxx for the amps, and subs!
exactly what i want in amps but i dont need 15's
what else do i need ...should i upgrade my alternator ....do you recommend anyone
i know about jpi just wanted to see if you knew anyone else
thanksagain
when you get that exhaust if you need help let me know
johnny
thanksagain
johnny
#104
anybody do the trunk lid strut thing on a GS yet??? i'd love to do that.....
sorry for threadjacking
is it possible ?/
i mean iknow anything is possible but is it
#105
Originally Posted by T.L.W.
TJ away J
is it possible ?/
is it possible ?/
at first glance I didn't think it was possible with the spacing under the lid being the way it is, but I'm sure it can be done with some extensive metal work, like you said, anything can be done.
jerry
