sc key wont work for glove box and trunk lock!
Old 06-06-05, 12:34 AM
DavE713
DavE713's Avatar
Default sc key wont work for glove box and trunk lock!
hey guys my key does not work for my trunk lock under the steering wheel and it wont work for my glove box.. i can open the truck in the back but the trunk pop inside the cars is locked plz anyone HELP!
Old 06-06-05, 12:45 AM
silversprucesc3
silversprucesc3's Avatar
Sucks...this means that u DON"T have the master key but rather the valet key.
My buddy has the same problem.. I believe the valet key prevents unlocking what you mentioned.
You will need to purchase a master key....
Old 06-06-05, 01:10 AM
DavE713
DavE713's Avatar
^^ how long will it take for the dealer to cut me one and how much do they normally charge with and with out remote??? normally dont a valet key just open the door and start the car?my key can open the tunk still and it has a remote
Old 06-06-05, 01:28 AM
silversprucesc3
I don't believe valet keys have remotes??? but i could be wrong.
Maybe the locks in question were changed by the previous owner?
I believe if looking for a master key, Lexus will need your name and vin#.
There is also a clublexus sponsor that does keys... check the banners..
Old 06-06-05, 01:35 AM
DavE713
DavE713's Avatar
see the things is that both the glove AND the truck pop wont work
Old 07-14-05, 12:18 PM
Gus400
Gus400's Avatar
I had a key laser cut at a locksmith, it worked fine for the ignition, but not the trunk or glovebox. After comparing to my master key, I noticed it didn't have the ridge along the sides of the key cut out. ( Like the Valet Key) I took a dremel tool and a small disc and cut it out, and it unlocks everything now.
Old 02-18-21, 11:46 AM
2001tundra
2001tundra's Avatar
Do you have any pictures of what the “ridge” is? Is it a bevel or an addition to the cut down the center? I had some keys cut at Lexus of Seattle and they were supposed to be masters , but they function as valet keys. I am hoping to do the dremel, disc modification to make them fully functional.
Old 05-10-21, 06:07 PM
rsvpdavid
rsvpdavid's Avatar
i say you drill it out.
Old 10-16-22, 08:15 AM
paulpiker
6th Gear
paulpiker's Avatar
use any tool Press the tool in behind the latch and by moving it and prying on the door , you will be able to get the glove box open
RG250
CL of Southern California
04-30-12 03:19 AM
RG250
04-27-12 11:30 AM
drewkaree
17
08-09-08 07:07 PM
xssax
10-12-06 11:41 AM
Shines34
SC- 1st Gen (1992-2000)
12-28-02 11:32 AM
Quick Reply: sc key wont work for glove box and trunk lock!
