SC400 Cd Changer Problems/Questions
Hi guys, there is a problem with my 12 CD changer that is driving me nuts. It no longer works and I dont know why. The CD button on my headunit does not even light up nor does the eject button on the changer unit itself which led me to believe that it was not receiving any power. Well I checked each and every fuse and they are all OK. I also checked all the connections and they were also all ok. Anyone might know what the problem is? Thanks a lot.
This unfortunately doesn't help your situation of mine - but - I have PRECISELY the same problem with mine. I've got a 1993 SC400 with the Naki system in it.
Not having a CD player is raw!
Anyone know about this? I'm searching on the subject right now (which is how I found this post to begin with) so if by chance I do located the answer I'll come back here and make an additional post with a link to what I've found.
Cheers.
Cheers.
Well -- the next thing you would want to check is the actual power signal or the lack thereof at the unit-- using a multimeter-- I've had a plug under the backseat need replacing completely-- I mean 17 wires I had to reterminate with butt splices --
All the wires were broken due to corrosion from moisture getting in the car I presume when it was broken into-- (there was quarter glass everywhere under the seat) --
Check the plugs-- It could be as simple as giving the changer a new power lead-
