how do you end engine noise?
Make sure you have all the paint scraped off if you're using the body for groundings. Make sure that it's not too long, I think 12" or less.
Check your ground again, try different points, good connections......I'm just throwing suggestions out there, I'm sure you did all this.
Initially I tried a filter, didn't help me.
I did everything as mentioned above: running the separate wires, good grounds......
I think I'm repeating myself b/c this is all I know and what worked for me when I had the engine noise
6SOARER
05-03-09 05:02 AM
white ice
01-05-06 09:23 PM
