change out the speakers...
Tech Guru
Here is a step by step instruction to remove and replace the factory speakers, 4" to 5.5" Polk Audio Component.
also, the factory speakers are 2ohms rating, aftermarket are 4ohms ==> less power to the speakers, but still make very good sound
here are the bolts on the door that you need to remove
4 bolts at the bottom of the door
more picture comming....
Notes: I will not be responsible if you break something
Tech Guru
1 more bolt around there
nm
After remove ALL the bolts, you can pull it out, very easy, if you need to force it out, you are missing a bolt somewhere
Tech Guru
finally
final product =) , now a 50k car will sound like a 50k car That's all I can say. even with factory system
double sided tape for the crossover, and zip tide it down
that's it folks, i also did the transmission cooler also, but some one already posted the pix for it =) very helpful, thanks whitediamond
Next weekend, alarm, oh no, i got to be out of town next weekend... more later then
Anh
Anh
