speaker baffles...
i built some front speaker baffles to house my new 6 1/2" speakers. i must've gotten the specs wrong because the speaker hits the door panel.
it was built out of 1/2" MDF with a 1" spacer ring. should the spacer only be 1/2" (for a total baffle depth of 1") ?? The depth of the speaker is 2 13/16" and it seems like there is still some room between the window and magnet...
thanks.
thanks.
it is the Alpine 6 1/2" spr-175a. the mounting depth is 2 13/16" so will this not fit?
and for the baffle, i should cut out a 1/2" spacer and mount it to the 1/2" board for a total depth of 1", correct?
Moderator - Electronics Forum
More than likely it will not fit. I've tried some MW170 Dynaudio speakers (3 inch mounting depth) and they needed way too much clearance. You can try the 1/2 MDF and 1/2 spacer combo but I'm pretty sure that the magnet will hit the window as it's coming down. The 1/2 MDF and 1 inch combo that I'm using works fine to a certain speaker depth...up to about 2 1/2 inches.
Percy
Percy
Percy,
What is the mounting depth for the Dyn. MW160 driver? Would the 1/2 inch baffle and 1 inch spacer work? or would it be a really tight squeeze. I went to their site and they said it was 77 mm but that would be about 3 inch mounting depth which is the same as the 170 which I know shouldn't be right.
hmm. maybe i'm doing something wrong because with the 1/2" mdf and 1" spacer combo, the spacer still hits the door panel - even without a speaker... does your setup clear the door panel easily?
ok percy, maybe this will help. i can't figure out why it doesn't fit! this pic is with a 1/2" mdf and 1/2" spacer. from the spacer, the lip and rubber of the speaker extends about 5/16". it is still hitting the door panel..
Core,
Try positioning the speaker a touch lower and trimming down the spacer ring to the exact diameter of the speaker. Be careful when cutting. Hopefully this will help a bit. Nice job of the baffle board though! My setup will hit the door slightly but I made sure that the speaker cone doesn't hit any part of the door.
Percy
Percy
thanks percy. i'll give that a shot. there seems to still be some room behind the magnet, so maybe i'll also cut down the spacer a bit more. if it still doesnt work, any suggestions on comparable speakers to these Alpines? i'll be pushing them with the Alpine MRD-F752 5ch amp. i'm not quite ready for Dynaudios yet...
well, the Alpines just weren't gonna fit... mounting depth was too big. so i picked up some Boston Acoustics and they fit in perfectly! i even mounted the crossover to the back of the speaker baffle for a really tight setup. thanks again for your help percy. i'll post pics soon...
FuMoFFuTT
SC- 1st Gen (1992-2000)
15
06-25-10 10:54 PM
