battery relocation
ok i want to relocate my battery where the factory amp use to be. i did a search, and was told to start a new thread. so here it is. how thick does the wiring have to be and where is the best spot to ground? can i use my amp wire it look just as thick as the wire to the battery? thanx
Zombie Slayer
No. Your factory amp wire is not the same guage as the battery cable. Go to a PepBoys or Strauss and get some 4 gauge battery cable. You really can't go too thick, only too thin. The heavier gauge wire the better. As far as grounding, any CLEAN spot is fine, so find an exising screw hole, clean it up and attach.
Zombie Slayer
i'm sorry i am using an aftermarket amp wire would that be ok? it looks to be the samne size or a tad but bigger.
