93 SC - Radio replacement?
My 93 SC has a non-op radio - the sound is not amplified any longer. With the volume turned to "Max" you can barely hear the sound. Any suggestions on a replacement radio/cassette player? The CD changer is in the trunk (of course.) I'm also selling the car so want to have this corrected before I sell. Thanks.
Most definately. I don't know all too much about audio, so someone else may have to chime in, but you have an amplifier as well, and that could be the culprit instead. Search a bit and see if anyone else had the same issue before you spend your had-earned cash on the wrong thing.
Scott
Scott
May not be the radio. I had a few different issues with my stock system. I expereinced the exact same problem you describe but the problem was a blown amp. The location of the stock amp is also a place condensation settles resulting in a rusted bottom of the amp. Before long...poof! No more amp. By your statement that you have no sound, I assume you have a Nakamichi stereo system? If so, check amp first. If you have Pioneer system, which uses 2 amps, then check radio.
andrewdees
08-27-08 07:33 AM
kaidoy
01-27-05 04:01 PM
