Basstube in RX330
Basstube in RX330
Anyone added a powered basstube to their RX330?
I want some more bass in the car, but don't feel like spending more than a couple hundred bucks nor do I want to rip the car apart. Just want to add a little more lows. Its actually my GF's car, I drove it today and the lows sounded a little weak.
She has the ML system in it.
How are those wired up anyway?
Originally Posted by jpcdmd
ok now whats the easiest way to install it?
The Basslink comes with all the wires you need to install.
Also, you will have to bolt it down, so take into account that you will have to drill into the RX, b/f buying.
+ = run a line from the battery with a fuse
- = tap into the car's metal body
acc/remote wire = tap into the stereo or something you know that requires power when ignition is on like the antenna if it's an older rx.
input L and Right= I remembered tapping + from one rear speaker and - from other rear speaker.
Anyone can correct me if I'm wrong, but this is what the instructions said.
