CAlling all audio Guru's
HELP!!!
I did the carPC in my GS and with the sound card that i'm using sound is amazing. Even with the factory speakers. My only problem is that when raise the volume to try to get her loud, my amp goes into protect! Current Audio Specs:
Bull***** 360 watt 2 channel amp Running at 4 Ohm.
I switched out the factory sub for a 10" 200 watt Dual Sub. (Good ENough) I beleive it runs at 4 ohm
I'm still using the factory Door speakers I hear that they run at 2 ohm. Is this true?
Could the difference in ohm's be causing my amp to go into protect.
TIA guys/gals
TIA guys/gals
Are you using that single amp to run everything? And if so I don't see how can hook the sub and the door speakers to only 2 channels.
If you want to use just one amp for the whole system, look for a 5channel amp. 4 ch for door speakers and 1 for the sub.
vital
03-26-18 10:45 AM
runnerlk
08-02-14 10:17 AM
