Sc400 trunk subs question...
i just put 2 12's in the trunk and i still have my stock sub behind the rear seat. they are both controlled by the bass **** on the stock HU, i get enough bass into the cabon. when i have the trunk open the bass is about 3 times louder. thats what i want, i would much rather have people outsdide of the car hear me, what can i do to the trunk so people outside can hear it clearer from a distance...im kind of a show off kind of guy . i want more sound outside of the car. thanks
Your stock sub is killin you bro, take that out and you'll get so much more air into the cabin. Also remove the stock sub amp, and DEFINITELY the fuel pump cover. All these will increase the bass sooooooo much, then when u open the windows, people will hear you comin from blocks away
Run the wires from your headunit (aka before the amp) rather than after. This is supposed to be the "correct way" anyways. Or if you dont wanna do that, just leave the amp in, its the other 2 things that make a big difference.
so if i just unplug the stock sub and take it out and leave the amp is there a problem with doing that? and what do i have to unplug to remove the stock sub and how do i do it? how long should it take? and can i leave the sub cover on over the rear seat? would it make it better if i took it off?
gsean400
03-06-14 11:10 AM
