Where do i buy a SC400 stereo install kit?
Old 12-31-05, 05:43 AM
1badceli
1badceli's Avatar
Originally Posted by cheungsta
err...so is there a wiring harness for the SC3/4 that I need to get? I'm having it installed over the weekend, and should probably pick it up if I need one......
Nope!! No wiring harness!! You will have to hardwire the old fashioned way. You will need to find the power/ground/constand/ETC... and speakers as well. I have to do the same
Old 01-02-06, 09:29 PM
88supramki
88supramki's Avatar
I already gave you all of those, you just need to run the wires to the speakers if you're running of the deck. If you're running an amp for the speakers then you should run the wires from the amp directly to the speakers. Hit me up again if you didn't keep the color codes, I saved the page at my office.
Old 01-04-06, 12:20 AM
BigManne
BigManne's Avatar
you need to bypass the factory amp if you are going to use just your deck
Old 01-07-06, 07:49 PM
Psionic
Psionic's Avatar
I am a little confused. I used the scosche toyota dash kit and the scosche toyota wiring kit on my 92 SC300. The wiring kit worked flawlessly (except sub.. that will be taken care of with a new amplifier), and the dash kit worked ok (there was a small gap that needed to be fixed... minor flaw).
Why does everyone say these kits dont work?
Old 01-07-06, 11:08 PM
1badceli
1badceli's Avatar
Hmmm.... Well i tried the same wiring kit you got and no luck?!
RedPhoenix
05-31-07 09:38 PM
-92SC400-
02-23-07 10:54 AM
YZFR1
07-10-05 05:09 PM
gompka
GS - 1st Gen (1993-1997)
46
11-03-04 08:37 AM
tony400
03-11-04 04:51 PM
Quick Reply: Where do i buy a SC400 stereo install kit?
