Extending Battery Cable
How are you guys extending your battery cable for the positive side?
I want to change out the battery terminal but i would need to extend the wires a bit.
I have this battery terminal
http://www.darvex.com/miva/graphics/...1/BTP-705N.jpg
Left upper side will be the from the alternator and the right side will be my power cable for the amps.
Can i simply chop the factory terminal and use two of these with a bolt in the middle to join the new wire to extend to the battery? And of course the whole connectors will be shrink wrapped and wrapped with black tape
http://www.darvex.com/miva/graphics/00000001/btc18s.jpg
EDIT:
Nevermind, i found what i needed http://www.darvex.com/miva/graphics/00000001/SCOUP0.jpg.
EDIT:
getting to my alternator is kinda hard. The supercharger bracket is in the way. So i figured extending it would be easier until i actually have time to do it the right way.
Everything in Moderation
the key is to keep the resistance of the extended wire very low, and to keep it from corroding so it stays that way. you can use aftermarket terminal blocks, splice blocks, etc.- just be sure connections are very solid and protected. I always cover/seal the connections in plenty of dielectric grease - you can get it in little packets at PepBoys, Autozone, etc.
Mike234588
09-11-16 11:27 PM
