That's it I give up
![Thumbs down](https://www.clublexus.com/forums/images/icons/icon13.gif)
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
this is for the pioneer system
Maybe someone come over & electrecute my Oem system because i've had it with this ONE..
I've had it since november. I took out the aftermarket unit (which was playing)
Installed a headunit from a 97 sc. The antenna worked after I install the OEM HU & I could hear a little sound coming from the speakers. & that was the beginning.
A few weeks later I bought oem amps . seperate 1 for the sub & the other one for the rest of the setup. No sound anymore but antenna still works.
NOW i got some new connectors/plugs & a 12 disc cd changer. & now system wont even turn on. ITS DEAD.
Can a sc300/400 OEM system guru tell me what im doing wrong here.
Oh & btw I've tested all the fuses (front & inside) & all the fuses are good.
Maybe I should just take the whole thing apart & just install an aftermarket one. I can't take it no more. I gotta have my sound
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
Also a few other stuff that isnt working : cigarette lighter unit ( Dont use it but i want it to work). The darn side mirrors.
I'm wondering whats next
PS
I DID SEARCHED
Everything in Moderation
You mean you have no power, not signal. You need power first.
Have you checked the battery voltage with your ohmmeter directly across the bat terminals? check to see that the meter reads 12V or greater. If not your meter is dead. Replace the battery in the METER.
timmy0tool
09-04-14 01:01 AM
