Ported Or Sealed
Right Now I Have Four 10s In My Ls400,and Iam Upgradeing To 4 12s I Was Going To Go With 6 But I Think I Will Be Happy With The 4.what Type Of Box Should I Get A Ported Or Sealed.
You might want to consider sealed because w/ 4 12's a ported box will probably take up the entire trunk.
Sealed sounds a lot better imo.
But go for ported if you're into spl.
i dont really care about spl.i just want it to be loud.i noticed ported makes it hit deep and low.and sealed boxs make it louder and more of a pop then a low boom.what is your ipotions
Ported vs. sealed can sometimes be dependent on the particular subs. I have 2 Diamond 12's and ran them in a sealed enclosure for about 3 years until i found worksheets for tuned ported enclosures on the Diamond Audio webpage. The enclosures had a port tuned to 32 hz and upon completion and installation I would never go back to sealed, at least not with those subs. Your sealed enclosure will have a tighter punch andmay have tendencies to make the amp "work harder" to power the drivers, where ported generally have a more drawn out boom and not be as punchy, however dependent on the type of port the enclosure has, the bass won't necessarily be drawn out. I would see what the company who makes your driver recommends.
GSteg: damn you are everywhere
Sealed boxes suck.
Ported you gain effeciency on the sub system. It WILL play louder with any given power than a sealed box.
Get some good subwoofers, like Digital Designs, and you will get the sonic accuracy of a sealed box (due to their super tight suspension and hand built quality) but with the effeciency of a ported enclosure (Digital Designs drivers are all designed for ported boxes) They have VERY high power handling as well, so you're gonna get insane results with DDs.
Some of the loudest competitors use Digital Designs.
Good equipment will net you better results than trying to stuff in as many subs as you can.
10" Digital Designs 9900 Series. 3000W Musical power handling, 6000W peak power handling
![](http://www.*********************/images/products/284/7951c0.jpg)
Originally Posted by natesiy
Sealed boxes suck.
Everything in Moderation
4 12"s??? There is NO QUESTION that you want a PORTED BOX. You're looking for loud, not quality. You don't need sealed, it will dampen the loudness. You may even want to section off the 4 woofs and port each section separately to prevent too much interaction between them.
6 12"s?????? BTW, before you decide on ported vs. sealed, you may want to get a price on some new ears. I hope you're only usng this for SPL shows and not driving that way. This is fine if you're doing SPL competitions with ear protection, or you're outside of the car. You only get one set of ears, and once you get over 2 or 3 woofers you're in the very high risk category. Watch out. You won't hear your ears going by the way, as they're on their way out the door.
What, don't believe me??? BS, you say?? I am co-developer of the world's first disposable hearing aid. Believe it. I get very concerned when I see these set-ups. Don't go so crazy that you lose your hearing. It's not worth it.
old fourm but,i have decied.i have all my amps and batts and subs.i have for 15s and two 1500 watt rms amps.there prob going in sealed...because if i go ported each sub requires 4.5 cubic feet of air space.and my trunk is not that big.so i guess were going with sealed.thanks for all your input
DJ SprinklesNJO
22
06-18-02 08:32 PM
