99 GS 400 - Which cigarette lighter wire should i tap for remote turn on?
03-14-06 | 12:25 PM
searched and searched the forums, tons of threads but none say which wire to tap...any ideas before i try this install?
03-14-06 | 06:29 PM
Your best bet is to get yourself a 12V testing light and test out which wire is hot when the key is on ACC.
03-15-06 | 04:00 PM
pink is positive remote and green is ground
03-15-06 | 11:36 PM
Yeah just use a testlight and tap in from the fusebox. Connect the wire to the side of the fuse that does not read hot when the fuse is fulled.
03-17-06 | 04:38 PM
Just take the wire to one end (thats exposed) and go see if your amps on. If not try the other one. That should help yah
03-17-06 | 08:18 PM
Oh and use the cig lighter that is under the head unit - it is the easiest one to get to
03-17-06 | 09:35 PM
why aren't you using the remote turn on wire from the headunit???
did I miss something?
If you tap the cigarette lighter wire, will your amp smoke???
g3ner1k
ES - 5th Gen (2007-2012)
01-13-15 06:28 AM
1SLOGS
12-11-13 11:28 AM
pwrdbyrice
08-19-08 09:51 PM
TampaIS250
10-09-07 08:52 PM
maxi-milli
11-22-05 10:00 AM
400 ,
99 ,
cigarate ,
cigarette ,
cigeret ,
fuse ,
gs ,
lighter ,
ligter ,
located ,
remote ,
tap ,
tapping ,
turn ,
wire
