VCD and SVCD
VCD and SVCD
Does anyone know if the stock ML/Nav in the IS350 is able to play these formats? My ride is in storage until the 1st and I want to start burning some videos to play when the nav hack is done and want to know if it plays SVCD as well as VCD(I believe all DVD players play VCD)
I don't even know what that is , could you explain and tell me how to do it?
KVCD is a modification to the standard MPEG-1 and MPEG-2 GOP structure and Quantization Matrix. It enables you to create over 120 minutes of near DVD quality video, depending on your material, on a single 80 minute CD-R/CD-RW. We have published these specifications as KVCDx3, our official resolution, which produce 528x480 (NTSC) and 528x576 (PAL) MPEG-1 variable bit rate video, from 64Kbps to 3,000Kbps. Using a resolution of 352x240 (NTSC) or 352x288 (PAL), it's possible to encode video up to ~360 minutes of near VCD quality on a single 80 minute CD-R. The mpeg files created will play back in most modern standalone DVD players. You must burn the KVCD MPEG files as non-standard VCD or non-standard SVCD (depends on your player) with Nero or VCDEasy.
Using KVCD parameters to create DVDs (KDVD), will enable you to create 100% DVD compliant MPEG-2 streams, capable of playing on any standard DVD player. This will allow you to put up to about 6 hours Full D-1 720x480 on one DVD, or about 10 hours at Half D-1 352x480.
phenomeno
10-05-14 06:08 AM
Jump2man3
10-09-13 06:32 PM
