Has anyone considered updating their 2nd Gen GS to have a push button start.........?
Old 03-17-06 | 06:39 AM
Hameed's Avatar
Hameed
EV ftw!!!
Originally Posted by kietlander
good info. there you go .... smart key and push-button start with out spending more money on a new car. i wouldnt mind doing that to my car. and hey if you want to go even a step further... get magic touch door kit. it opens ur door when you touch a certain part of the door.
And how does that work? Does it only open when you are in the vicinity i.e. the car key is in your pocket?
In other words does it work in a similar fashion to the way systems like this work on the new IS for example?
Old 03-17-06 | 07:52 AM
933005spd's Avatar
933005spd
If you want to just walk up to the car for unlock and have a start button, I would consider using an RFID or prox card system.
Using RFID would give you a few feet distance. Probably what the newer cars are using. Prox cards need to be inches or right on the reader.
Wire in a couple relays this would be very possible. Why just add a start button if you need to use your key in the ignition anyway? That takes me back to my '76 BMW Bavaria.
Good luck
Old 03-17-06 | 07:57 AM
Hameed's Avatar
Hameed
EV ftw!!!
Cool, thanks!
Good luck
This is what we have been saying all along - nobody wants to do that..........
Old 03-17-06 | 08:15 AM
933005spd's Avatar
933005spd
Default Okay, ideas
Here are some items you could use. Hope your good with hacks....
Keyfob:
http://www.secureorderprocess.com/ti...?product_id=47
Reader:
http://www.ti.com/rfid/docs/products...STU-MRD1.shtml
So, basically what you need to do is:
1. Wire in the reader with the appropriate circuitry (this is the tough part. you may need to program a 'basic stamp' for this) See here: http://www.digikey.com/scripts/dksea...+stamp&site=us
- you basically need the logic to:
a) when it sees a recognized card, unlock door... which doors?
b) when a above is done, activate the ignition circuitry
c) on push button start do xxx
I would estimate parts prices to be under $500.
Peter
Old 03-17-06 | 08:31 AM
Hameed's Avatar
Hameed
EV ftw!!!
Keyfob:
Reader:
Peter
Awesome! Now all I need to do is find someone qualified to do this for me. Does anyone know of any electronics shop that does stuff like this?
I will not even bother attempting to do this myself. The most complicated DIY job I can do is an intake install and changing bulbs.
Old 03-17-06 | 11:09 AM
tonydt1g3r's Avatar
tonydt1g3r
its easy I could do it. Just watch out when ur battery is dead
Old 03-17-06 | 11:21 AM
933005spd's Avatar
933005spd
You should do it then, probably could make some bucks from an RFID keyless aftermarket kit.
Why would the battery be dead though?
Current draw in active mode for the RFID receiver is only 100mA in active mode. In passive it is only 5mA. That is less than an alarm LED.
You could always use an alarm keyfob to 'disarm' your alarm and put the RFID into active mode.
Old 03-17-06 | 11:39 AM
Hameed's Avatar
Hameed
EV ftw!!!
I'm all ears.............
Old 03-17-06 | 11:54 AM
tonydt1g3r's Avatar
tonydt1g3r
I think we are going off topic with the RFID stuff. Maybe that should go in a new post. Back to the ignition stuff hameed get a button and look up the instruction on how they handle the remote start so you know which ignition wires to tap. same concept.
Old 03-17-06 | 12:48 PM
Hameed's Avatar
Hameed
EV ftw!!!
Actually it is not off-topic - I specifically asked about this type of technology for the door handles.
Me, tapping wires? You gotta be kidding me bro.
Old 03-17-06 | 01:02 PM
tonydt1g3r's Avatar
tonydt1g3r
So I assume your not one of those do it yourself type of people huu. You best bet is to contact an alarm installer and see if they can do it for you. Theres going to be some splicing and sodering involved.
Old 03-18-06 | 08:35 AM
Hameed's Avatar
Hameed
EV ftw!!!
Noop suggested I post this thread on http://www.the12volt.com/installbay and the response was so fast and very detailed! http://www.the12volt.com/installbay/...TID=74673&PN=1
Now I just need to find a local installer who knows Compustars very well!
Old 05-29-06 | 02:29 AM
kissbang's Avatar
kissbang
Push start button? Quit trying to steal my thunder!!
Anyway, yeah. It may be pointless but hey, it's cool. From what I know, I think you have to hold down on that button until the engine turns, right? As opposed to just a quick press and release. I'm not sure, though.
Old 09-09-07 | 12:43 PM
B.Diddy's Avatar
B.Diddy
Lexotic Concepts
Any success in this? I am looking into retrofitting an RFID proximity card type entry and push button ignition sytem into my car as well.
Old 09-09-07 | 11:44 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100000
after catching up with about 6months span of posts i wanted to add that Yes, it is doable and has been partially accomplished by a couple guys on a 350z board.
the main problems are bypassing the Steering Wheel lock, and configuring the RFID system (not a problem for any EE familiar with thte tech.)
Range would also be an issue, Lexus has sensors all over the car for its keyless systems on new cars, thats what lets you walk to the trunk and have it open.
if you JUST want the look+feel+SOME of the security you could just hardwire the button in and have a magnetic reed switch hidden behind a panel that you would have to trip with a small magnet in your keychain to put the car into ACC/ON mode
NCDUB
07-13-09 08:57 PM
Str8 VIP
12-18-08 09:05 PM
