6x9 speakers in the rear?
hey i have a question..how hard will it be to install 6x9 in the rear of my 92 sc300..i did a search..all i found was..u can do 6 1/2 no problem you just gota drill ur own holes..but no one talked about 6x9..
see for back then when i had a honda...u can just take the back board out n cut a hole to fit 6x9..but i dont know about lexus? any idea??
also..fa the front..poeple said u gota mod it to fit 6 1/2 speakers...but for the 5 1/4 speakers..does it fit perfectly?
Originally Posted by kietlander
u can do 6x9 rears, same thing u just have to cut ur own holes. good luck with that one. fronts will fit 5 1/4.
well putting a 6x9 isnt hard. the hard part is make the hole for it. Then you cant use the stock grill u have to use the one that came with the speakers. i dont like how that looks, but its ur car. then with the 12" u can put it in. but u wont have much room in ur trunk. and dont forget to remove the stock sub if u put in ur 12.
bezee
09-13-05 01:54 PM
