GS400 Stock LCD Screen/Display Info
Found on us.lexusownersclub.com regarding the LCD screen/display on the GS400:
GuyTelefunken
Mar 12 2004, 01:10 AM Post #5
In case you are interested in the factory look, all you need is part no CWM4931 - LCD DISPLAY ASSY which you can get directly from Pioneer. It's a matter of a few simple screws to replace. Cost is $100.83. I did mine a few months ago. Very easy.
http://parts.pioneerelectronics.com/...Num=KEXM8076ZT
This part applies to the standard model with the cassette, not sure if it fits the Nacamichi. If you call Pioneer at 1-800-228-7221 they will be happy to help you. Take the radio out to get the exact model number if you need it. Here's how you get it out.
http://www.carstereohelp.com/stereor...usGS400str.htm
Note you can't just buy the LCD part no CAW1385 because it is held to the rest of the assembly with a proprietary conductive bonded flex ribbon cable that is not possible to bond back to the assembly after you remove the display. I don't even know why they sell it seperately.
Sidenote: It is actually the connections on this cable that fail, but the good news is the replacement part has been redesigned with a metal clip at the connection point. Surely this will make the display last longer. I must have seen 15 Lexus cars with this problem already.
I also found in a different post on CL that the '98+ OEM Pioneer non-Nakamichi head unit is part number is KEX-M8076ZT.
Enjoy!
Brian
GuyTelefunken
Enjoy!
Brian
ddrigsby
08-10-13 07:21 AM
