Inside the MARK LEVINSON amp...
Moderator - Electronics Forum
ML amp opened up.
Analog Devices SHARC processor. More info found here.
http://www.analog.com/en/prod/0,2877...21065L,00.html
11 pairs of NPN/PNP discrete power transistors. 2N6488/2N6491 pairs.
http://www.datasheetcatalog.com/data...4/2N6488.shtml
2 capacitor banks, one totaling 14,400 microfarads, the other totaling 18,800 microfarads. Standard issue caps, nothing special about them. Electrolytics.
One small fan to cool the whole unit. The rest of the cooling relies on the outer chassis. ML packed ALOT into the amp/processor. The higher than normal (compared to pioneer/nak) mortality rate is more than likely due to heat.
This amp was donated by one of the CL members (thanks Nate!) for me to look at.
More pics to follow.
Percy
Percy
RogerHomeB (04-27-21)
Richie,
The only thing that I could update/upgrade would be the filtering caps. Probably drop in some Black Gate/Rubycon (they work NICE!) or some Nichicon MUSE. Other than that, there are little banks of components right by the npn/pnp power transistors. Have to take a look to see what they do. Pretty tough to upgrade the board since it's a 4 layer design. Even taking out the caps might be risky if the solder doesn't flow correctly to all 4 layers.
There's also that layer of epoxy all over the main board. Still, the SHARC chip looks pretty darn cool. If I had the time, I wonder if I could make it adaptable to the pioneer/nak systems.... would have to find a source for those darn plugs.
Percy
Percy
Everything in Moderation
This thing doesn't look bad for a factory-installed unit. Still NOTHING like an aftermarket unit. I'd say even a crappy aftermarket amp can equal it. Not even worth upgrading caps or other parts. The base stuff is just not there.
Those TO-220 packages for the 2N transistors are a bit wimpy, especially for dissipating heat. Surprised they didn't use MOSFETs...I'll bet this thing goes non-linear if you push it too hard. Probably geared for the average Lexus driver that isn't going to rock the neighborhood.
The SHARC is always cool.
Very nice..thanks for the info...
Question for you guys...I have access to an AMP MANUFACTURER and DESIGNER...Can I have this amp modded to have FULL SIGNAL Stereo output "PRE_AMP???
I would like to know this in advance before I go about ripping my amp off and sending it in.
MIke
MIke
MIke
MIke
Cool pics. Can you tell me if there are any internal fuses in the amp? I'm currently troubleshooting loss of audio in my 03 LX470 and none of the external fuses are blown. I really don't want to remove the amp if I don't have to.
Thanks in advance.
Thanks in advance.
Glad to hear that you didn't take apart the amp from your car!
Thanks in advance.
Thanks in advance.
Percy
Originally Posted by drck1000
Donated for the sake of our curiosity huh!
Percy
this is off the subject a little but I have the old Nak setup in my LS and I am wanting to upgrade the sub only. When I dug into my trunk and got to the amp I was confused by all the wires. Nothing is labelled and I cannot seem to find the sub wires. Are you guys familiar with this amp? What I am wanting to do is take the sub signal before it gets to the stock amp and run it to a different amp and sub. I assume this is possible. I have pics of the wires if that helps. They aren't great pics but they show the colors. Thanks in advance.
