quick feedback regarding Dynamat....
Old 04-24-06, 10:31 PM
saelee39
saelee39's Avatar
Default quick feedback regarding Dynamat....
i am getting jl audio xr components installed in my 2000 gs in 2 days, and i was wondering if its worth
1. putting Dynamat Xtreme on all doors since im putting in component sets?
2.since im doing the whole trunk, would you do the doors?
3. would my car smell like asphalt or anything?
please list any negative and positive comments regarding dynamat extreme, i would like to know before i do this...
Old 04-25-06, 12:54 AM
vin 78
vin 78's Avatar
Dynamating the doors will make a world of a difference, and not it won't smell like asphalt.
pro's:
easy to work with and works well
con:
heavy and expensive
Old 04-25-06, 06:17 AM
T0ked
T0ked's Avatar
Just one thing to keep in mind... If you want to ever get that paintless dent removal in the future, the dynamat will prove to be a real hindrance. If that is not a concern I agree reduces noise tremendously.
Old 04-27-06, 07:44 PM
rwheelz
rwheelz's Avatar
I was thinking of dynmatting the doors also, never done it though. Is it as simple as spraying some adhesive on the metal under the door panel, and cutting out a piece of foam to fit it?
Old 04-27-06, 08:33 PM
88supramki
88supramki's Avatar
yes do the doors, yes do the trunk, no it won't smell like asphalt, if you can afford it do the whole rest of the car
Old 04-27-06, 09:45 PM
vin 78
vin 78's Avatar
Dynamat has adhesive on the backing, so there's no need for any spray adhesive.
Old 04-27-06, 11:49 PM
88supramki
88supramki's Avatar
oh yeah, and get a small rubber roller and some gloves when you do it. the roller will make it easier to make sure that it is applied best, and if you don't use gloves be prepared for metal cuts....think about paper cuts and then kick it up a notch or two...not fun...
ERILUDE
06-08-07 11:10 PM
antboy
16
09-20-06 12:43 AM
01IS300
IS - 1st Gen (2001-2005)
05-10-04 02:01 PM
biggie27
04-17-02 02:02 PM
Quick Reply: quick feedback regarding Dynamat....
