igniter
igniter
i have this question. i went to circuit *****ty to get an alarm put on my sc300 93 this was a few months back. every since i have had little issues like my clock reseting my amp thump on and off. but anyway i have been doing some work on my car and i noticed that they used the igniter for power and ground for the siren and hood pin. this alarm has never worked right. should i be concerned?
I personally would be VERY concerned, this installer ( I am one BTW) did not know what they were doing and would be fired from my shop. the prefered place to access power and ignition is the main ignition harness under the dash, as the wires there are of thick enough guage to support add-on accessories, and grounding the siren should be done at the siren, using one of the mounting screws, the hoop pin is self grounding?? or should be?? I personally would not have driven out of the shop until the alarm, etc worked to my satisfaction. This may have meant an extra day of inconvience, but now taking the car back again and again, will stress you out. make sure that the STORE"S general manager is involved, not just the shop manager, and you should get some results.. get what you paid for!!!! PS. did they even put fuses on the power wires?
12volts white & white/red + ignition harness
Starter black/white + ignition harness
Ignition black/yellow + ignition harness
Second Ignition blk/orng + ignition harness
Accessory red + ignition harness
Power Lock green/yellow - passenger kick panel
Power Unlock green/white - passenger kick panel
Parking Lights+ green drivers running board
Parking Lights- green steering column
Door Trigger red/white - drivers kick panel
Trunk/Hatch Pin red/white/silver dot - drivers running board
Hood Pin grn/blu or grn/org - hood switch
Trunk/Hatch Release blue - switch
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock green - drivers kick panel
Tachometer black ignitor
Brake Wire green/white + brake pedal switch or dkp
Horn Trigger green/red - steering column
shern
03-25-08 11:53 PM
tropical
03-29-04 08:52 PM
