Just replaced factory Sub
Everything in Moderation
I assume you ran the existing sub wires into the inputs of your amp - AND your amp input sensitivity is set to SPEAKER LEVEL INPUTS, or you've used the wire input connections for speaker level? If not, your performance will suffer.
Have you used the correct output terminals of the amp - for bridged mode?
Where do you have your amp gain set? You may want to crank it up a bit?
You are going to have a hard time figuring things out if you just try to gather all your information here and try to put it all in one. What you need to do is go back to circuit city, gather all the fantastic info we provided you here that you still don't understand and simply ASK AWAY. Its their responsibility to explain and answer your questions.
Good luck
Good luck
![Wink](https://www.clublexus.com/forums/images/icons/icon12.gif)
Originally Posted by handzilla
So I couldn't hold off on the upgrade any longer. I kept my factory stereo, removed the factory sub and purchased installed a Kicker comp 12" Sub and a Kicker amp from Circuit City. Some songs bump real well but I don't think the system is up to par. It sounds like some frequencies just aren't hitting right. Also the output into the cabin doesn't seem as good as it should be.It cost a pretty penny and I'm not sure I got my $$ worth.
Obviously I know very little about all of this. I'd appreciate any advice, recommendations, or suggestions on this. Thanks.
Check out my thread...
https://www.clublexus.com/forums/sho...d.php?t=219750
I have the similar setup but the only difference is the AMP..
kmn5
02-16-06 09:01 PM
BananaGS
10-03-02 01:14 PM
