Just replaced factory Sub
So I couldn't hold off on the upgrade any longer. I kept my factory stereo, removed the factory sub and purchased installed a Kicker comp 12" Sub and a Kicker amp from Circuit City. Some songs bump real well but I don't think the system is up to par. It sounds like some frequencies just aren't hitting right. Also the output into the cabin doesn't seem as good as it should be.It cost a pretty penny and I'm not sure I got my $$ worth.
Obviously I know very little about all of this. I'd appreciate any advice, recommendations, or suggestions on this. Thanks.
Originally Posted by Spyder78
have u checked the amp settings? Also if you are using the original headunit thru a hi-lo adapter you will always have sound loss.
. what amp did you get? is it one or two 12's. using your factory radio you will not get the best sound. i hope ya bought the city advantage plan lol. i work in the roadshop here in my town. i know a little about that stuff. you might want to look into going with the kicker CVR's instead they sound a million time better
I got this amp: http://www.circuitcity.com/ssm/Kicke...oductDetail.do
and the dimensions of the box are 43.7(W) x 38.7(H) x 40.2(D) cm
that is one crappy amp. Change it. 200 watts max when bridged at 2 ohms is nothing. I would just return the amp and buy online the prices in circuit city for amps are out of this world.
BTW his box measurements are in CM in inches they would be 17.48x15.48x16.08 . Now estimating thickness of would is 3/4 than the interior volume of the box would be 1.88 cubic ft.
hey..i use to work at C.C. also...installer..i use to tell people that came in wating a amp that puts out 500 watts for $200 dont bother..ull b back mad at me for selling it to u...my rule of thumb was a buck and some change a watt for pricing amps..500 watt amp...be ready to pay $500 to $700...just my 2cents
How many ohms is your sub wired to??
Also, check what setting your amp is on. OFF/LP/HP Meaning high pass, low pass, a setting for different type of frequencies/bass. Make sure its on LP or OFF.
If its on the off possition, the power is in the hands of your deck, if its in the LP possition, use the frequency **** on your amp.
Low pass is for lower frequencies (Subwoofer type frequencies)
Someone correct me if i'm wrong because i got my facts straight just today
