Thinking of upgrading sub in 01 GS300 for higher SQ
Everything in Moderation
1) remove stock sub, use as planter or paperweight
2) buy prefab enclosure for 10" - sounddomain.com - Obcon is a great one to get. Get sealed enclosure for your type of music.
3) mount woofer in enclosure
4) mount enclosure on trunk ledge
5) add LLC to sub wires and add your favorite amp (run new power wires (fused) from battery)
6) sit back with favorite malt beverage, pina colada, or mixed drink & enjoy
PS: I would have recommended a Boston woofer for you. Also infinity Kappa Perfect. The Alpine will work for ya though.
ok thanx a lot man1!!
i can get a new prefab sealed 10" box for $37 CAD + tax at my local futureshop (owned by bestbuy)
may i ask what LLC is?
also is that the stock sub amp right beside the stock sub? (on the right of it)
so i just hook up those inputs to the new amp?
mmm wish i can have a pina colada now
actually i might just go ahead and make one right after this post
lol
thanx in advance too AZ-GS300
LLC is a line-level converter.
No, that's not the amp next to the sub, it is the plastic box that holds the rear center seatbelt.
Using an LLC, you run the existing sub wires into it, then run the output of it to a new sub amp. Do a search for LLC if you want to know more.
ahaha all this time i thought lexus put a tiny pioneer amp and i thought thats the amp there
lol
so wheres the stock sub amp?
or does the sub run to the multi channel amp in the glove compartment?
or with LLC, i just run the amplified sub wires into LLC and then run LLC to new amp then new amp to new sub?
lol
lol
lol
"or with LLC, i just run the amplified sub wires into LLC and then run LLC to new amp then new amp to new sub?"
ah ok i see
it seems like LLC is fairly cheap
basically just converts pre-amplified OEM wires to RCA output right?
are all LLC made about the same?
are there any particular brands i should avoid or look for?
thank you so much
thank you so much
not all LLC are made the same. I highly recommend getting your LLC from www.davidnavone.com. He's a genius at car installation. There are a few LLC to choose from, so if you want, drop him an email and he'll usually respond back within a day.
ok thanx
i just emailed him
asking him which is the LLC that i need and questions regarding shipping
before he answers me, is this what i need?
http://www.davidnavone.com/images/pr...NE7V/NE7Va.jpg
i just emailed him
TWO CHANNEL HIGH QUALITY LINE DRIVE ADAPTER
NE-7V Introductory $19.95 (regularly $39.95)
Order NE-7V .:| Here |:.
The Navone Engineering NE-7V is a stereo, full-range speaker level to pre-amp level line output adapter with balanced and/or common outputs, full transformer isolation, an adjustable output signal level that ranges from zero up to 9.5 Volt Maximum RMS, and a powerful infrasonic filter on the bottom end. The inputs of the device connect to the car's left and right speaker leads that are provided, and the gold-plated RCA female chassis mount outputs feed into the input of an aftermarket equalizer, electronic crossover, or power amplifier. The fully isolated circuitry eliminates DC ground loops and provides excellent coupling with a high input impedance. The source impedance of the Navone Engineering NE-7V is low enough to be considered a competition grade component. The output range adjustment (0 to 9.5 Volts) permits a wide range of OEM decks to perfectly interface with a wide range of aftermarket components. However, we highly recommend leaving the trim pots at the MAX level. To optimize the signal and minimize the system noise, we also recommend using the Autosound 2000 Test Disc CD#104, Level Setting, to perfectly set up your syst***s gain structure.
Hope these are what you needed:
![](http://www.paulhillmaniii.com/GS300/trunk/slides/IMG_0392.JPG)
![](http://www.paulhillmaniii.com/GS300/trunk/slides/IMG_0393.JPG)
![](http://www.paulhillmaniii.com/GS300/trunk/slides/IMG_0394.JPG)
![](http://www.paulhillmaniii.com/GS300/trunk/slides/IMG_0395.JPG)
![](http://www.paulhillmaniii.com/GS300/trunk/slides/IMG_0396.JPG)
![](http://www.paulhillmaniii.com/GS300/trunk/slides/IMG_0397.JPG)
edit:
Personally, I HATE prefab boxes. Unless they're designed with a specific sub in mind or they're the right size for the sub you choose. A sub will sound so much better in a properly sized/designed enclosure. They can work. But they generally aren't as efficient.
LLC's convert high level (re: speaker level) signals. Since subs are generally designed to handle more power, make sure you get an LLC that will handle the additional power. You can't pull preamplified sub signals since they don't exist. The amplifier is the whole signal processor as well.
edit:
Originally Posted by AZ-GS300
edit:
If you buy a GOOD prefab box like Obcon, there's no difference. You always MUST get the correct size box for your enclosure. (There is usually a range, not just one size.) Prefab or not has little to do with efficiency. Ported vs. sealed will have a greater effect.
Most LLC will have enough output for the amp's preout. The sub doesn't pull power from the LLC so no need to get a really expensive one.
The only thing you really need to look for is the output, the amount of channels, and such. It'll vary from applications to applications. The one you picked will work in your case, unless you plan to add another amp(s) for your mids later on.
thanx everyone
and thank you very much for the pics AZ-GS300
heres the prefab box i got
http://www.futureshop.ca/catalog/pro...0061802&catid=
external size is about 1.7 cubic ft
my friend has a class D bazooka amp that he can sell me
and a free LLC that he can give me too
things are going alright now
with LLC, do i have to keep the pots on the amp at max?
or doesnt matter?
also must I remove the stock sub?
i wouldnt mind keeping the trunk sealed to create an even more tighter base
ill disconnect it but leave it in the rear dash
would that cause any problems?
also should i keep the sub pointing towards the door of the trunk?
or towards the side?
or doesnt matter?
i tried fitting the empty box in the trunk
it fits that insert in the trunk pretty darn well
takes up half of that space
i would say its a great fit and it doesnt slide around with the carpets getting enuf grip
so should i keep the stock sub in the panel to keep the trunk sealed or take it out?
The only thing you really need to look for is the output, the amount of channels, and such. It'll vary from applications to applications. The one you picked will work in your case, unless you plan to add another amp(s) for your mids later on. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
[/quote]
thanx everyone
http://www.futureshop.ca/catalog/pr...10061802&catid=
my friend has a class D bazooka amp that he can sell me and a free LLC that he can give me too
or doesnt matter?
LLC = line level converter. These take the high level (i.e. amplified) signals from the head unit/amplifier (those signals that normally feed actual speakers) and output them in the 2, 4, or 6V signals that the amplifier RCA inputs read. Your biggest concern is whether the LLC will handle the amount of power the source lines are outputting. If you put the LLC near enough the amp, you can have any amount of output. It won't matter. You would simply match the output of the LLC via the amplifier's gain control.
