Diagram removal of 2001 RX300 radio?
Does anybody have diagram pictures to take the radio off a 2001 RX300? Is it just clips holding the wood part down? And if so, where to I pry it open from? Thanks....
First,
Very carefully insert a taped screwdriver below the wood trim down the shift gear to pull up the wood trim. Be carefull and gently to avoid damages. Use a small and tiny screwdriver
Put the shift in L.
Pull out the wood trim taking out all the swtiches if any (Heated seats, etc)
Then the only thing that you have to do is screw out the 4 nuts that you will find that fixes the radio to the dash. In Europe are sized 10 mm. Pull out gently.
Remove all the connectors from the radio and screen, that is all.
(Sorry for my english)
Put the shift in L.
saloom
06-06-16 07:48 AM
shawndh
02-05-08 06:00 AM
xsuperjoex
06-14-01 06:00 PM
