MB QUART DWE-254 or MTX T4510-44 Subs?
MB Quart Specs
* 250 watts peak
* 175 watts RMS
* Frequency Response: 25-300 Hz
* Dual 4 ohm voice coil
* Polypropylene Cone
* Butyl Rubber Surround
* Cast Aluminum Basket
* Rubber Magnet Bottom
* 5-Way Binding Posts
* Vented Pole Piece
MTX Specs
* carbon-filled poly cone with foam surround
* frequency response 35-150 Hz
* power range 50-225 watts RMS
*peak power handling 450 watts
* sensitivity 87.6 dB
* 250 watts peak
* 175 watts RMS
* Vented Pole Piece
MTX Specs
Im a big fan of mbquarts from the headunit to the subs in my car everything is quarts but my crossfire amps and audiocontrol processors .If you can upgrade get the PWE-252 or PWE-254 premium subs by mb quart for more power handling
