easy subwoofer upgrade for gs
#46
a really good application for a free air sub in the GS i a Boston G110, fits very nice in the opening and sounds great off of a small wattage amp. the Boston also has a nice rubber seal around the mounting holes in the sub, so no need to seal for good sound
#51
Recommended Enclosure
0.5ft ³ (14.2 L) volume sealed
For a G110.
This is not an infinite baffle sub.
I would recommend listening between this SUB or any infinite baffle sub against a sealed or ported box.
Sealed is tighter bass.
#52
HAS ANyone done this but with the factory amplifier...???
just an easy replacement and keep the same amp...
HAS anyone done it with the kicker C10 and factory amp...
thankz
NEZ
thankz
NEZ
#53
The factory amp does not have enough power to push most aftermarket subwoofers. Keep in mind that the OEM subwoofer was built for sensitivity to run off of the OEM power. Most aftermarket subwoofers require more power.
You can power the Kicker C10 with the OEM amp, but you will probably not be very happy with the output. In fact, the output might even be less.
#54
kooo...thankz GSteg
you know what...ill be doing this really soon,, ill be posting up pictures of it..too..im going to be running a small amp for it...but might as well put a better woofer...will see...
check soon for some pics....thankz
nez
nez
#55
Great idea Engin Ear. However, this all assumes one has removed the stock 2GS IB subwoofer.
I assume there is no easier way around removing the stock top mounted IB subwoofer accept to go through the whole 'removing the back seat to access the packaging shelf' routine described elsewhere...?
Lexsterone
Lexsterone
#59
thankz
thankz
#60
time to resurrect it again lol
I seached, but may have overlooked, so my apologies in advance for asking if this is already answered somewhere.
What is OEM subwoofer wattage?
What is OEM non ML stereo wattage sent to sub? (also curious about other channels power as well) The reason I ask this is I have a high level to low level converter so i can use stock stereo with an amp.... but it can only handle 50 watts.
really hate to ask a total newb question, but its been a few years since i built a sub box.... what is MDF board? I saw what it looks like, but if I go to Home Depot or Lowes, can i just ask for MDF board? or does it go by another name?
Other than the Kicker C10.... are there any other recommendations for a good sub, that is competitively priced? The Kicker C10 can still be bought for around $45-60 online.
Thanks for the help. and Sorry again for any duplication of questions
