want to replace stock sub
i want to replace the stock sub in my 02 es300. i know you all have read this a million times but i figured id ask in case there has been any new subs the search button didnt find. i want to use the stock amp in possible but i have a kenwood 1000 watt amp if i need it. im looking for only a nice name brand 10" thatll fit right inot the stock spot.... anyone got any opinions? also... how the heck do u get to the stock sub? take the seats out most likely.... clips? bolts? help? thanks
Yes. I drove the LFA.
I wouldnt really recommend using the stock amp to power an aftermarket sub... it would likely be very underpowered. I suppose it all depends on what you are looking for. If you are looking for a lot more bass, i would install a sub, in a box, in the trunk, leaving the stock sub alone, and adding an aftermarket amp to power the new sub. If you put a sub in the stock location, and plan to power it with a big amp, you'll likely not get that great of sound and probably get lots of rattles from the rear package tray... i know others have installed aftermarket subs in the stock location, but i dont think any have used the stock amp to power it...
im def not looking for big bass man... high school is over for me. im just looking for a free air 10" sub that i can put in the stock location and have "ok" bass. not loud loud LOUD bass. im over that faze of life. where the frig is the stock amp BTW?
purchased a Kicker 05C104 10"... sounds like it does the trick. im hoping to just bridge the stock amp (if i ever find out where it is... all though i havent even looked!!!) cause its peek is 300w and the rms is 150. had nothing but great reviews also. if i cant bridge the stock amp and have it sound good, can i just hook an aftermarket amp up using the power/ground/remote the stock amp uses? i wouldnt see y not but i never tried to do this where a factory sub a=has been present.
olddog
10-24-06 07:40 PM
Shnerez420
08-12-05 09:32 AM
