Incredible but suspicious..
Old 10-09-01, 12:08 PM
LS400
Club Lexus Editor
LS400's Avatar
Default Incredible but suspicious..
5 JL W3 15's powered by 5 amps. In a Geo Metro..now it is up to 171 dB. Is this possible?
Old 10-09-01, 12:50 PM
Mean Gene
Mean Gene's Avatar
Thumbs up Very Possible
E - I've seen the same JL advertisement & sure, it's easily possible. The Metro isn't very large to begin with so U've already got a small pressure chamber. Ainsley Fukuda did 159+ with two RF Power DVC 15's with a Power 1100a2 on each sub ( in an S-10 extended cab P/U ) & that's w/o any tuning. For me, the biggest question is which meter did they measure the pressure on? Check out some of the various organizations "World Records" to see how much variance there is. My friend's at Ace Audio still use the gold standard B&K meter ( which I THINK only USAC uses ). It generally registers lower pressure that other mics; hence USAC SPL records tend to be lower than other organizations.
Old 10-10-01, 06:28 PM
Mean Gene
Mean Gene's Avatar
Question In What Ryde?
E - The monoblock amp's a great match with the 15W3 sub. The amp pushes 500 wrms & the sub's rated at 400 wrms ( but there's always some dynamic headroom built into the specs ). I guess it would depend on what your enclosure was like as to how close to 171 dB U could come. Be fun though!!
Old 10-10-01, 08:01 PM
retrodrive
Search Function Inc.
retrodrive's Avatar
It's all about installation and environment. IF you take a VW Bug and put 10 layers of dynomat extreem into it, wall off the back seat and do a nice little port, you would get insane SPL.
Old 10-10-01, 09:23 PM
Mean Gene
Mean Gene's Avatar
Wink Yep!!
E - That's exactly what high SPL "sounds" like. Pretty much anything over 145 dB is a "Brappp" sound. Read in this month's Auto Sound & Security that the editor compared it to a burp - close enough!!
Old 10-12-01, 03:30 AM
LexDriver18
LexDriver18's Avatar
When I get passed 145db... I'll tell ya how it sounds!! ;-)
IF I can still hear?!?!?
Old 10-13-01, 10:09 PM
sirsomo
sirsomo's Avatar
Hey guys, long time no post. I am a JL fan, but there ad is a little misleading. Those W3s had an excursion somewhere in the neighborhood of 3''. I do not know who built the subs, but they are not stock. I would assume they're some sort of JL prototype or the shop modded them. Maybe the same technologies as the W7?
Old 10-13-01, 11:43 PM
Mean Gene
Mean Gene's Avatar
Lightbulb General Guideline
E - For SPL testing, usually the mic's 12" from the passenger side A-pillar; 4" above the dash & 1" from the windshield while facing it ( exact placement can be found in either the USAC or IASCA rulebooks, depending on which organization U compete in ). The one's I quoted R USAC mandated as USAC is where I compete the most. In Outlaw events I've seen them move the mic all around the cockpit to find the highest reading - believe sometimes they also allow raising/lowering of the windows as well ). Of course, in Port Wars the mic is stuck right down into the port of the enclosure!!:eek: For SQ testing, it's placed 26" above the driver's seat cushion & also facing the dash as in SPL testing.
Sirs - Yep, 3" of linear Xmax is right about where the W7's R supposed to move. Have ya had a chance to demo one yet? I've been busy with family things & haven't even been down to the local shop to check them out but I've got some vacation coming up in November & I hope to spend some quality time there then!
Old 10-14-01, 06:12 AM
itzloud
itzloud's Avatar
Default Stock W3's
Those subs were 5 bone stock 15 w3's and 5 EQ D2's...And is by no means easy to break into the 170's. The measurement was on termlab euipment (B&K expect about 6-8 db less). And NO you will not reach this goal with a 500/1 on each sub...Put a 1000/1 on each coil and you have got a start.
The coolest thing about that car is they did not blow 1 sub even running double their RMS (even through deathmatch:eek: )
Old 10-14-01, 08:45 PM
Mean Gene
Mean Gene's Avatar
Question Best Guess
E - Don't have access to a JL spec sheet but it's a safe rule of thumb ( for an SPL woofer ) that it will easily handle twice it's RMS rating. RF Power HX2's handle 400 wrms but 1000 watts peak so U'd be safe with a JL 500.1 on each voice coil. I suppose that the W3 would live with the 1000.1 on each coil in short bursts as well but haven't done any serious SPL competing in a decade or so. Things have come a long way since then ( for the better ).
Old 10-15-01, 01:27 PM
itzloud
itzloud's Avatar
Default W3's
Yes the 15w3 will take 1000 watts daily driving but anything more is really pushing it. For comps they can take alot more...That metro was burping 2000 watts to each 15.
Old 10-15-01, 02:17 PM
LS400
Club Lexus Editor
LS400's Avatar
itzloud what about vega strokers? I heard those things hit hard as well. are those capable of handling spl?
Old 10-15-01, 02:53 PM
LexDriver18
ITZLOUD,
Thanx for all the info. I had a question though. What kinda car do you have and what's in it stereo wise??
I have a 2000 GS400 and I'm plannin on getting 2 12" Kicker Solo-Baric L7's... (I already have one)
~What amp should I run to those to give me mid to high 140's??
~I might even like it to be in the 150's so that I can compete
but tone it down to 130-40's for daily driving.. can I do this?
~What do you suggest??
Thanx for your input and it's nice seein you on the boards!
Old 10-15-01, 02:56 PM
LexDriver18
and when I say compete.. I don't mean IASCA or USAC levels... I mean just local competitions at stereo shops near by...
I want my car LOUD!! I mean, I wanna be heard a BLOCK AWAY!!! I wanna pull up next to some punk kid with 1 12" in his S-10 and BLOW HIM OUT OF THE WATER in my Lexus...
So that's what I'm going for... Advice?
Old 10-15-01, 03:38 PM
retrodrive
retrodrive's Avatar
You would be going for DD9500 series and A LOT of Dynomat!
Quick Reply: Incredible but suspicious..
