radio not working
radio not working
in my 93 sc 400 my radio is not working i cheacked all the fuses and still nothing .did anybody ever had this problem ?can it be the vol /power button no good or the radoi itself?
Might be the radio/headunit itself. There is probably a fuse or relay somewhere inside the unit that could be blown. It could be the switch. It could be the power wire is unplugged (but I'll bet you checked that already). Could also be a ground not connected. Check the connections to the head unit using a voltmeter to assure there is power going in. If it does not light up and there is power going to the unit you may have to open it up.
RTNmsds
07-11-08 05:22 PM
