help w/ installing kenwood kna-g510 gps
I have the kenwood ddx-7017 and purchased the plug-in GPS unit. there's a couple wires i need to connect and wanted to know a few things...
Ground (Black)
Battery 12v (Red)
Ignition 12v (Yellow)
Parking Brake Sensor (Green)
Ground is easy.
Red/Yellow, can i just tap the same red/yellow on the radio wire harness? I assume it's the same thing as battery and ignition.
Parking brake sensor, can i just ground this wire out? There's a speed sensor wire on the kenwood unit so that it won't play dvds while in motion, but i just grounded that out and now it plays all the time. I figure the parking brake sensor is the same.
Thanks in advance.
PS. where should i mount the antenna? I was going to put it on the rear window but i have 5% tint, will that matter?
Ground (Black)
Battery 12v (Red)
Ground is easy.
Thanks in advance.
Ground (Black)
Battery 12v (Red)
Ground is easy.
Thanks in advance.
Ground (Black)
Battery 12v (Red)
Ground is easy.
Thanks in advance.
thanks.
yes, only my headunit is hooked up to the wires, and the headunit is double fused. also the gps unit has fuses on both the red/yellow wires.
i ended up mounting it on the front windshield which also has tint strip, but not the mesh like the rear. i figured this was the easiest route and since it's in a window it should be getting signals fine.
i'll report back results, thanks again.
for some reason the 'navigation' button is still dimmed out on the unit.
i grounded the parking brake and ground wire to chassis.
hooked up red/yellow to my red/yellow on radio harness. maybe i'll put the yellow to a straight ignition source. the red should be 12v so i don't think that's the problem.
APU6speed
07-15-02 09:43 AM
