Most of my older radios (eclipse 5303r and Sony C90, except the Eclipse 7301) used *****, and I really miss it .
I guess when you have a double-din you have to trade off the **** for the larger LCD screen.
Here's a good solution , add an eq that has vol , fader control
Lexkost, I had a Four.i until I just ripped it out when I put in the Nav system. That's exactly the **** I used for volume. Now I have a 30 band digital EQ in trunk. No more ****. Replaced the Four.i with an EPIC-160.
If they can come out with a digitally controlled **** (such as the one in the Sony C90) that doesn't suffer from dust contamination, that would be great. A good portion of the aftermarket manufacturers will use a simple potentiometer for the volume control, one that will degrade over time from the junk getting in there.
Percy
There's already a digitally-controlled **** out there - it's called a Rotary Encoder. Produces pulse train of a different phase when you turn it in opposite directions, & pulse speed increases as you turn it faster. These are all the ***** out there that turn and turn and have no stops on them. You're right, they generally don't suffer from dust contamination. If a **** has a stop as you turn it in each direction, it is an analog pot, and will degrade over time unless it's super-expensive.
Meanwhile, I've taken to using the volume on my remote, instead of constantly hammering the headunit.
