Please help me with the ohms on this JLw6v2
This is a jl audio w6 dvc. I'm not familiar with how dvc's work, but I need it to be 4 ohms. Can you please tell me if this is correct. It is a dual 4 ohm sub.
http://www.we-todd-did-racing.com/we...ZkMzF5NTQx.jpg
After reviewing the JL site, it looks like one sub can only be wired in 2 or 8 ohm . . . I think. Your wiring matches the 2ohm setup.
http://mobile.jlaudio.com/products_s...php?page_id=64
Can't be done with a single subwoofer setup . . . you need to get two of them (provided that the other one is also a dual 4ohm sub). What type of amp do you have? Power ratings (i.e. 500w x 1 @ 4 ohm bridged)? Is there a subwoofer crossover on the amp or head unit?
G
G
You could always switch it to the 8 ohm wiring setup . . . you will have about half the power (150 watts), but the distortion will go down and the damping factor will increase (amps ability to control the speakers movements). I sure hope you have a crossover in your head unit or on the amp to keep the higher frequencies from the subwoofer . . .
Also, you may want to address your vehicles acoustics . . . place the subwoofer in various locations (point it towards the rear, point it towards the front, etc) to check which area sounds the best. Deep bass needs to travel a distance before it sounds good. Even check it with your windows up and then down . . . You will be surprised.
G
G
yes you can with a W6. it's set up as a 4 ohm load straight out of the box.
you can play around with the settings if you wish, but straight from JL the final impedance is 4 ohms for a single woofer
Good luck!
Specs: http://mobile.jlaudio.com/products_subs.php?series_id=4
Wiring diagrams: http://mobile.jlaudio.com/support_pages.php?page_id=161
LuxuryGS3
06-14-14 05:04 PM
