auto-reverse camera
you need to pull up the section around the shifter, and test the wires that connect to the harness for your shift indicator. there's one that will generate voltage when your car goes into reverse. i'll be in my car in the next few hours working on it, if you can't find it by then i'll write it down and just tell you the wire you need.
Everything in Moderation
The part that was left out here is that there is an input to your headunit that is for "Reverse" on one of the connectors. They also give you a super-humongo long wire to be able to wire it to your reverse light in the rear.
hey 88supramki
can you tell me how you got to that plug.
I took off the wood stuff and found the plugs for the seat warmers,vsc and pwr ect but could not find the plug that connects to the shifter.
can u please show me some large pics showing how to reach it.
thanks.
mine is a 98 gs 300 if it matters
thanks.
mine is a SC3 which could explain the confusion. hmmmmmmmmmmmmm, i'll do some looking and see what i can find about that one. unless someone with a GS would like to chime in
well it's either a purple or green wire. that much i can tell you in my slightly intoxicated state
i know the red with white stripe is the parking brake wire. Hit up Engin_Ear see if he can recall the correct wire when he did his car
