Last abnormality before success; sub absence or wrong speaker connection
I hooked up my speakers but I haven't hooked up the sub cos am waiting on my 4 guage amp kit. Right now when I play cds the speakers sound kind of weird;the music plays but I can only hear certain highs and mids (like just the double voicing and the rest of the song in the background).
but when I swicth to radio, it sounds somehow normal but of course without bass.Also the nav voic/route guide sounds clear and nice from the speakers like it should.
Is the absence of the sub causing this or is my speaker connection wrong? I saw 4 wires for the front speakers from the a/market unit (1 pair of one color and another pair of another color) and I guessed they were R+,L+,R-,L- respectively.
So I connected the fronts like that cos they were 4 wires also from the stock harness. Same for the rear.One thing is when I switch the sound position to either the front right or left position, the sound becomes louder like normal.
What do u guys think? Absence of sub or wrong speaker connection?(if I wired the speaker wrongly, they shouldn,t sound at all right?
sorry for the long story but this the only abnormality in my install.
Input guys,please.
Input guys,please.
I was having the same issue when I installed mine on Sunday. Wierd sound like a main singer and a real far background singer right? I used the line level input and tweake dit a bit. I have everything working sub(kicker free air) and all speakers just as it was before the Navi. Still using the factory amps for everything. The only issue I am having is well 2 issues one I tucked my cig cord behind the radio so I have to use the arm rest lighter for my charger and my driver sidetweeter is not working. Sorry to rambnle but to answer your question you could have the wires in the wron direction meaning neg - pos instead of the normal way pos-pos. So you will get sound but it will distort the sound greatly. So I suggest to try a line level input after you flip the wires to opposite of where they are now.
hey
i swapped the speaker wires but same problem. when i set equalizer to flat and everything else to normal, it sounds as described(double voiceing parts are normal but actual song plays faraway in background.
it sounds normal when i set the POS (position ) to either font left or front right(which shouldn't be.)
any other input guys?
The absense of the sub will not cause any of those problems you are describing. There could be something wrong with your head unit, you hooked something up wrong, or your EQ settings are all screwed up.
Success Success Success
I finally got it.
it was allmy mistake.I thought because the speaker wires from the eclipse were 2 pairs of 2 different colors,I thought they were I from each pair for each speaker but no.
it is the 2 same colors for each speaker.
man the stock speakers are not as bad. they sound better with an aftermarket unit(way smoother and crisp IMO)
can't wait to hook up my stock sub with an aftermarket amp to see what it produces.
anyways thanks everyone . my install is great now
tftimm
SC- 1st Gen (1992-2000)
07-15-11 06:38 AM
sneakers
07-24-10 12:06 PM
SC400-V8
06-14-05 07:37 AM
Static911
11-27-01 10:20 AM
