Prefab Box Recommendations
I'm wanting to install one 12" JL sub in a ported box (preferably) in the following space in my GS4:
![](http://img57.imageshack.us/img57/9949/3fttrunkhj0.jpg)
(image borrowed from JUSTAKID)
I'm planning on running Zapco amps (1 for sub, 1 for the rest of the system) and need a good enclosure for the 12" sub. I would rather not custom build a box if it can be avoided. Any prefab boxes out there that will work?
Well, GS_Fonzy told me that if you want a ported box, it will use up most of the trunkspace, so im guessing you pretty much have to go sealed to fit into that space.
http://www.the12volt.com/installbay/...TID=74519&PN=1
thats a good site that shows you step by step how to make a good enclosure, for about 200$ and a good amount of time.
There's no way i'd build it myself. It isn't that i'm mechanically uninclined, it's just that i'm lazy!
I want to put 1 JL 12" sub in the trunk that's ported. If i can't find a descent prefab box, i'll just have 1 custom made. I've just confirmed the box will most likely by powered by a Zapco i-2100; it may be used to power the rest of the system, dunno yet.
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
I want to put 1 JL 12" sub in the trunk that's ported. If i can't find a descent prefab box, i'll just have 1 custom made. I've just confirmed the box will most likely by powered by a Zapco i-2100; it may be used to power the rest of the system, dunno yet.![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
A JL what? w7 or w6 or what?
you can find prefab boxes on the jl site
there is no prefab box made to perfectly fit in that space; that i know. a sealed box for 2 jlw3 fits perfect and a sigle 12 w7 ported will most likely need that same space. i think the box size is 31w 14t 12d. double check your self. box plus carpet makes a perfect snug fit.
TimChen
02-02-13 07:54 PM
2JZSHOTTAZ
08-25-11 05:03 PM
Mayur Patel
09-14-01 11:54 AM
