quesiton on aftermarket decks on gs400..help
well i wanted to get that pioneer d2 navi double din..however...i was told that if i replace my stock deck my stock sub and stock amp to my speakers wont work anymore..is that true? and if so..is there anyhting i can do to make them still work? becuase (well to me) the namacki system sounds pretty decent...again my car is a 99' gs400
thank
thank
if you use the search function, you will find a lot of answers.
if you change your stock headunit to an a/market one, you can use your stock speakers by wiring them to the headunit or wiring them to an amp and then to the a/market deck.
for the`stock sub, you will need to get a separate amp to run it. the stock amp is too intergrated to break down.
good luck
good luck
AmooManiaK
02-16-06 12:13 PM
Anatoliy
02-20-03 08:39 PM
