My new set up - no 56k
After getting a well deserved winter break from school, I finally have some spare time to mess around
The objective of this install is to have a low key and somewhat stock look.
This is the first install that i've done with an Elemental Designs sub.
After some listening with the amp gains turned all the way down, it sounds GREAT so far! It really deserves the name "SQ", although it won't break any SPL records (by it self at least), its far more then enough for my daily driver. It doesn't quite sound like my older IDQ, but it gets louder, and sounds fuller. Keep in mind that the enclosure is only 3" deep, it plays freeair too! Its worth every penny and some at $55 http://www.edesignaudio.com/edv2/pro...roducts_id=106
![](http://img398.imageshack.us/img398/6576/ed4we9.jpg)
![](http://img520.imageshack.us/img520/1896/ed3hf1.jpg)
Amp rack cover...
At this point, I still have a lot of sanding/grinding to do, as well as bondo, finish sanding and wrapping.
![](http://img296.imageshack.us/img296/5715/p1000062ob3.jpg)
![](http://img186.imageshack.us/img186/2829/p1000065lu9.jpg)
After a few hours of fiberglassing and several layers of bondo, here's the end result. The surface is not quite smooth enough got paint or even vinyl, but I'm using trunk liner, so its more then sufficient.
![](http://img408.imageshack.us/img408/6278/p1000077kv1.jpg)
![](http://img412.imageshack.us/img412/1885/p1000078sr7.jpg)
Test fit
![](http://img377.imageshack.us/img377/1637/p1000081zl3.jpg)
Here's what's behind the cover btw. I cleaned up too
Amp rack cover...
Test fit
![](http://img413.imageshack.us/img413/6217/p1000083yd9.jpg)
![](http://img411.imageshack.us/img411/7194/p1000093ag4.jpg)
![](http://img405.imageshack.us/img405/7190/p1000094ga1.jpg)
Next is the grille. My square grille wasn't totally "square", so I had to indicate front and direction :eek:
![](http://img443.imageshack.us/img443/6576/p1000091kl2.jpg)
I decided to use my router. Using a straight edge and a flush bit, the cuts are somewhat straight - my straight edge wasn't so straight however. I went ahead and passed the frame through my rabbit and round-over bits. NOTE TO SELF: I need a new flush bit
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
![](http://img101.imageshack.us/img101/1816/p1000092bp2.jpg)
Covering the frame with grille cloth. Notice that I had to modify the frame to fit over the amp properly.
![](http://img401.imageshack.us/img401/9973/p1000099yg2.jpg)
Tip: you get what you pay for when you buy 99 cent paint and primer...I had to cover it with 2 coats of primer and 3 coats of paint. The only reason why I decided to paint it black because I didn't want the tan MDF to show through the grille cloth.
![](http://img179.imageshack.us/img179/9493/p1000095bm5.jpg)
Mock-up. notice that I went ahead and cut the inside windows with the rabbit bit, this is because I eventually want to add metal mesh - I just can't find any right now.
![](http://img530.imageshack.us/img530/5453/p1000097wo5.jpg)
For those who has not tried adhering grill cloth to MDF, this is how I do it. I'm sure there are better ways, but this is the only way I know how.
Grill cloth...
![](http://img135.imageshack.us/img135/6527/p1000100yx9.jpg)
Using something that is 90 degrees and straight and hot glue, spread the glue in the "rabbit" groove and press down with straight edge. In my case I used my level.
![](http://img514.imageshack.us/img514/5466/p1000101lh4.jpg)
![](http://img176.imageshack.us/img176/7607/p1000103kx4.jpg)
![](http://img171.imageshack.us/img171/8738/p1000105fa7.jpg)
BE VERY CAREFUL!
![](http://img510.imageshack.us/img510/6488/p1000106tm4.jpg)
Finished
![](http://img136.imageshack.us/img136/236/p1000108bx3.jpg)
When I took this pic, the grill wasn't pressed in all the way, hence its not totally flushed.
![](http://img405.imageshack.us/img405/9383/p1000112il2.jpg)
![](http://img404.imageshack.us/img404/3383/p1000117tr7.jpg)
Here's a rundown at the equipment used:
Eclipse AVN6600 w/ camera and ipod controller.
Audiocontrol four.1
Phoenix Gold Basscube
Phoenix Gold Xenon 200.4 (200 w rms x 4)
ADS 334is (pre DEI) - kickpanels
ADS 236im (pre DEI) - rear doors
Morel 8" Midbass speakers - front doors
Elemental Designs - SQ10
WARNING: I used to install and I've learned to use safety equipment, such as work gloves, face mask and goggles. While cutting fiberglass and MDF there are a lot of airborne particles and eventually your insides will hurt. While handling fiberglass it can get very sharp, so save your hands and use work gloves, not to mention thin rubber gloves while working with wet fiberglass and bondo. I don't have to mention the benefits of work goggles.
So be safe If you intend to work with dangerous tools.![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Next up is the radio and whatever else I forgot to mention.
I'll keep you guys posted.
BE VERY CAREFUL!
Finished
Audiocontrol four.1
