Subwoofer wiring HELP!
Old 01-06-07, 04:44 PM
PIMPALA-SS
PIMPALA-SS's Avatar
and no, im not misunderstanding you.
the Nominal Impedance is what the amplifier needs to see.
his amp needs to see 4 ohm in a mono configuration (right positive, left negative) in order to put out its full power.
with two dual 4 ohm speakers, wired in series/parallel, or parallel/series, this is EXACTLY what he gets.
Old 01-06-07, 04:46 PM
88supramki
88supramki's Avatar
whatever you say man.......
Old 01-06-07, 05:01 PM
PIMPALA-SS
PIMPALA-SS's Avatar
http://www.cardomain.com/shop/woofer...dvc&x=121&y=12
pretty much every single wiring diagram on the planet, tells you to wire his amp this way.
what are you trying to say man? everyone in the world but you is wrong?
Old 01-06-07, 05:04 PM
88supramki
88supramki's Avatar
i'm just bowing out. I'm not saying that everyone is wrong. I'll be man enough to say that I'm wrong.
Old 01-06-07, 05:14 PM
PIMPALA-SS
PIMPALA-SS's Avatar
gapxguy, I'm sorry the thread turned into an arguement, but i wanted to at least make sure you had the correct information.
Old 01-06-07, 05:31 PM
vin 78
vin 78's Avatar
Wouldn't it be easer to just test the final impedance at the amp's speaker terminals with a digital multi-meter?
Old 01-06-07, 07:59 PM
gapxguy
gapxguy's Avatar
Not a probably at all, I like to be challenged and seek answers from more than one prospective. Thanks for taking the time to make those MS paint drawings too!
Old 01-06-07, 11:21 PM
PIMPALA-SS
PIMPALA-SS's Avatar
no problem-o!
Old 01-07-07, 04:22 PM
GS FONZy
GS FONZy's Avatar
gapxguy, your amp is not 1 ohm stable, you will blow it up if you hook it up like pic one.
i have a 500a2 and it has been hooked up like pic 2 for six to seven years,
i have not had any problems with it. 4ohms out speakers, 2ohms when bridged
88supramki was trying to tell you the same thing.
Old 01-07-07, 05:40 PM
gapxguy
gapxguy's Avatar
Fonz, I recently changed my wiring from the first picture I posted (16 ohms ) to option 2 picture you posted above (4 ohms).
It looks like RF configured their 500a2 to rate @ 4 ohms when bridged in MONO. Therefore, it's gonna be 4 ohms from the amp and 4 ohms from the combined subs, am I right? Is this the match we're looking for?
thebeeguy
10-05-09 02:03 AM
2Fast0
04-28-06 09:26 PM
Allenchang
01-03-06 12:01 AM
joshoowa
10-04-05 10:19 AM
mcnelson
10-28-03 02:44 PM
Quick Reply: Subwoofer wiring HELP!
