10" free air sub do drop into sc400 deck
ok, well im sure this has been asked before but my search doesnt work, anyways... im looking for a 10" free air sub that will fit right into my 93 sc400, i think its got the pioneer stock amp... can someone point me in the direction of a good one? also, is it hard to swap cause im a total noob with stereo stuff, also, would i have to switch out the amp?
i think youd have to run a diff amp if you wanted to run a diff sub. im not sure but www.caraudio.com/forums they reply alot faster and can help you on your selection
here are some links to most of the question you will have. try using the search function, it will help as well. good luck with your upgrade.
https://www.clublexus.com/forums/sho...79#post2332579
https://www.clublexus.com/forums/sho...d.php?t=250630
https://www.clublexus.com/forums/sho...d.php?t=244054
Zombie Slayer
It SHOULD drop right in. I went with a JL Audio IB 4 10". I had to open up the hole since I had an 8" stock. From what Have learned so far, some cars came with a 10", some with an 8". Either way you can still make it work. This shows just a sample of what is involved in opening up the hole.
https://www.clublexus.com/gallery/sh...9&ppuser=25727
Aristo300
01-07-07 07:48 PM
handzilla
14
04-27-06 05:31 AM
-Lexstacy-
07-14-04 06:15 PM
scfreak
04-30-02 12:22 PM
