Aftermarket stereo pics?
hrm... i know but i have to have the din tray to slide into the slot, since my deck has no holes. becuase its a tray with a pull out stereo.. so that din bracket needs to be in there.
ug.. no i have to have the din support on my deck its the onyl way my deck will work.. becuase its not a normal deck, its one that slides in and out of the car.. its a pull out unit.. so it relys on the din tray.
well stereos mounted... that was a 2 1/2 hour project.. ill post pics soon.. eletrical is next.. ill post pics when its done.. wow what a process.. anyone have any insite ont he electrica before i proceed tips ect?
Becker Mexico Pro single CD/Tuner (optional 10 Disc changer), I felt the only unit which would look good had to be the same flat black as the air-con controller. Shame the Becker illumination is only Red or Orange (reversible).
Usual mounting problems, fabricated the original brackets to hold the unit in place.
I will be replacing the lower pocket to install twin boost gauges (when I get time).
Right now the PS2 is coming out of the dash due to the new cross bar on the cage. The dash will look stock again... I don't have pics of my trunk install, but that is being redone right now as well do to the new cage install. I will post pics of the trunk when it is done. Just thought I would give you an idea of the way my dash looked.
-Ethan
I mounted the DSP control in the glovebox, and constructed a 1.5DIN panel from carbon fibre with a nice thick glossy epoxy coat and a fiberglass backing, looks real deep, meters will be fitted there when my motor is done.
CheVelleSS
SC- 1st Gen (1992-2000)
136
08-24-19 02:54 AM
FSUnoles
09-19-14 05:20 PM
