How To: Build and Hardwire an Auxillary Input to OEM Stereo
Old 12-19-07, 02:08 AM
  #181
Champak
Champak's Avatar
I will venture to say that this set up will work on any car. It is just a matter of finding the right wires. Also this should work on anything with a line out or headphone jack, so your Iphone should be fine.
Now for my question: I tapped the 12V wire going into the hazard light switch for my relay power. Now since I've done this, the winter cold has set in. The problem is, twice my battery has died on me after not driving for about three days; so I don't know if it is because of this set up or because of the cold. Does this relay setup drain power...does it matter which way the switch is flipped when the car is off...should I have not tapped the thick 12V (wire with power in it) wire going to the hazard light switch? Which problem is it?
Thanks.
Old 12-19-07, 12:08 PM
  #182
PureDrifter
BahHumBug
PureDrifter's Avatar
Thanks.
well theoretically it will only work on cars with an external signal source feeding into the headunit.
well if the relay array is NOT being powered then no, it wont cause any drain on the battery.
when it IS powered, its drawing a MINUTE amount of power, so i highly doubt that its the array thats causing ur problem.
sounds more like a battery in its death throes from the cold.
Old 12-31-07, 01:21 AM
  #183
GlobeCLK
GlobeCLK's Avatar
you got PM Puredrifter
Old 12-31-07, 03:24 AM
  #184
timywong
timywong's Avatar
just finished this for my first gen gs.
https://www.clublexus.com/forums/sho...6&postcount=16
Old 12-31-07, 03:51 AM
  #185
PureDrifter
BahHumBug
got your PM, you should have a reply right after new years
nice dash setup (i run playlists so i didnt wanna see the ipod ) i linked to your post in the 1st post
anyone whos got proof of this setup installed into their car (1 of each model please, so no 2LS or 1GS needed ) pls PM me or post up and il add u to the first post.
edit: 7700 posts even
Old 01-01-08, 06:40 PM
  #186
timywong
timywong's Avatar
ya i was just going to use my old ipod and hide it and use a remote, but i like this setup for now. ahah
Old 01-01-08, 10:37 PM
  #187
rgarjr
rgarjr's Avatar
PureDrifter,
I drew up another diagram hope you dont mind..
I'll probably do this mod for my Satellite Radios on my 98 GS300 with the Pioneer/NAV stereo. I'm currently using the cassette adaptor which sound very nice, but would prefer direct injection...
Old 01-01-08, 11:07 PM
  #188
rgarjr
rgarjr's Avatar
Old 01-02-08, 12:40 AM
  #189
PureDrifter
BahHumBug
Originally Posted by rgarjr
PureDrifter,
thanks!!
what program did you use to make it? it could come in handy for my next project im going to edit ur pics into the OP
Old 01-02-08, 10:57 AM
  #190
dashan
dashan's Avatar
Hi, Tracy,
Is ONE R95-117 all you need for the project?
Thanks
Originally Posted by tnltracy
Hi all,
Just completed this integration in my 1996 LS. Works great. Big props to Puredrifter for the IM support on the wiring. Primary difference is the wiring is in the dash vs under the pass seat.
In this application you use:
pin9 White CDR-
pin10 Black CDR+
pin11 Green CDL-
pin12 Red CDL+
Also can tap the Blue/Yellow wire from pin 5. I got a few pix and will post them over the weekend. Works excellent.
I have a slightly lower volume on the input with my JVC Sirius radio, but this has been true on other applications (Audi/VW), so expect it's the receiver.
Old 01-02-08, 04:53 PM
  #191
rgarjr
rgarjr's Avatar
Program is AutoCAD 2008.
Old 01-02-08, 11:13 PM
  #192
GlobeCLK
GlobeCLK's Avatar
PureDrifter, I just sent another PM to you with some more info
Old 01-03-08, 02:29 PM
  #193
damon
damon's Avatar
Very nice work & timely due to some Christmas gifts I received.
If anyone has a few units completed please let me know.
My soldering skills, like my eyesight have diminished over the years.
Happy 2008 all!
Old 01-05-08, 05:10 PM
  #194
rgarjr
rgarjr's Avatar
Just got done doing this mod on my car.. worked just as expected
I'll post some pics of the install soon.
Old 01-06-08, 07:02 PM
  #195
skperformance
skperformance's Avatar
Any one set this up with 2 inputs so you can have sat radio and and ipod hooked up and switch between them without unplugging anything?
Quick Reply: How To: Build and Hardwire an Auxillary Input to OEM Stereo
