How To: Build and Hardwire an Auxillary Input to OEM Stereo
Old 02-18-08, 01:12 AM
  #241
PureDrifter
BahHumBug
PureDrifter's Avatar
looks good, i just drilled a hole in the side of my center console (inside the lower inner portion)
Old 02-18-08, 02:23 AM
  #242
trackball
trackball's Avatar
Originally Posted by trackball
anyone know if there is a good switched 12v source in the SC400 trunk near the factory amp / cd changer?
to answer my own question (based on the diagram here), it looks like the following wires will work fine for a switched 12V source and a ground on the factory SC400 stereo :
Cable harness on the Factory Amplifier (larger 14-pin connector)
A10 (NCA ?? wire) [GND]
A14 (grey wire) [ACC / 12V switched]
Old 02-18-08, 05:41 AM
  #243
labtec
labtec's Avatar
thanks...i think i'm going to rewire mine. right now its to a 12v constant.
Old 02-20-08, 07:18 PM
  #244
handXgunz
handXgunz's Avatar
I really want to do this mod, but I am afraid that due to my inexperience I feel that I will mess something up. Do you think that if I took this diagram to my local car audio/video shop they would be able to do this, or would they charge me an arm and a leg??
thanks.
Old 02-20-08, 08:23 PM
  #245
rgarjr
rgarjr's Avatar
It really isn't that hard to do. Just need to find out which wires to cut and then solder them back on. It's actually fun doing this mod.
Old 02-20-08, 11:21 PM
  #246
PureDrifter
BahHumBug
contact RTGS400, he MIGHT have a spare set of soldered relays.
Old 02-21-08, 06:50 PM
  #247
handXgunz
handXgunz's Avatar
I thought this might help those confused about the SC. It helped me figure a few things out.
http://www.intellexual.net/faq/lexusstereo.swf
Old 02-22-08, 08:25 AM
  #248
labtec
labtec's Avatar
i think those diagrams are wrong...they don't match the wire numbers that puredrifter gave me, which worked just fine
Old 02-25-08, 03:16 PM
  #249
jimmyjay
jimmyjay's Avatar
Originally Posted by jimmyjay
My 2000 ES non-Nak system is the same way, I believe. I took off the glove box yesterday and discovered no direct connection between the amp and the headunit.
Based on what I can determine from reading the entire thread I would connect the device between the CD changer and the head unit. Puredrifter, would you be so kind as to confirm this? Thanks.
Finished connection between CD changer and head unit. The Ipod source sound mixes with the other input sources (AM, FM1, FM2 and tape) when they are selected. Does anyone know if this is to be expected with this setup or did I do something wrong?
Old 02-25-08, 03:39 PM
  #250
PureDrifter
BahHumBug
sounds like you tapped the wrong wires.
you needed to tap the black, red, white, and green wires on the back of the headunit, pins 1, 2, 6, and 7 on the R3 (12pin) connector. in order these are R+, L+, R-, and L-
Old 02-25-08, 05:33 PM
  #251
jimmyjay
jimmyjay's Avatar
Wouldn't those be the same black, red, white and green wires going into the CD changer connector?
Old 02-25-08, 07:46 PM
  #252
PureDrifter
BahHumBug
yes, pins 1,2,6, and 7 respectively (R+, L+, R-, and L-)
be careful since there are 2 red and 2 white wires on each harness, and only ONE of each is the sound, the others are the data transmit wires.
Old 03-01-08, 05:04 PM
  #253
jimmyjay
jimmyjay's Avatar
OK, I'm stumped. Checked and doubled-checked wiring from harness. Still have ipod source on top of other input sources (AM, FM1, FM2 and tape) when switch is on. Not a big deal to just turn the switch off to listen to other sources, I guess.
Old 03-01-08, 07:32 PM
  #254
rgarjr
rgarjr's Avatar
The audio from the IPOD (AUX IN) can most likely overcome the signal from AM/FM, TAPE. I would just have it CD mode to hear the AUX.
Old 03-02-08, 10:54 AM
  #255
PureDrifter
BahHumBug
hmm, thats unusual but i dont know how/why since ive never actually worked on an ES stereo.
but yea, just use CD so that you dont get any background noises...
Quick Reply: How To: Build and Hardwire an Auxillary Input to OEM Stereo
