How To: Build and Hardwire an Auxillary Input to OEM Stereo
#376
Thanks. I will see if I have those wire colors today, and if so I'll fix my system.
Edit: those wires are not even on my changer harness.
#377
I have a problem here.
My AUX relay is working great, except that it's draining my battery too fast. If I don't drive my car for 2 days my battery would be completely drained. The switch is there so I can just turn it off, but it's really a hassle, and I would like to know if this fast draining problem is common, or if there's something wrong. Thanks!
#379
Or why don't you just tap into an ACC+ power wire? That way it will turn off power to the relay when you turn your car off.
BTW PureDrifter, did you happen to find the wiring guide for the 94 LS400 CD changer harness in the trunk?
Thanks
Thanks
#382
I think in his case some crackling would be better than a dead battery (although I doubt the relays take that much energy).
Does anyone know where I can find out the cd changer wiring guide on a 94 LS short of buying a repair manual?
#384
would something like this be easier?
http://forums.mbworld.org/forums/sho...threadid=24707
Using a tape adapter and hard wiring from there?
it's been done before it's a pretty big pain in the ***, your dealing with stuff there where if you screw up and burn the board it's shot for the most part. i started to do it that way at first then said the heck with it when i ran across this thread.
#385
and if you base it off a tape adapter it defeats the purpose since you could just use the tape adapter, and will either way be frequency limited.
#387
Ok...I fixed the problem I was having. Apparently the wire colors going from the cd changer to the amplifier DO NOT match up on the 94 LS. The four wires (Light Green CDL-, Violet CDL+, Blue CDR-, Pink CDR+) are all bunched together on harnesses on both the changer and amplifier, but on the amplifier these colors don't correspond as written above.
Now, I am trying to find an opening in the trunk to run a wire to the front seat without ripping too much apart. Any ideas?
#388
Es300 (2000)
I read the entire thread and learned how to add AUX-input to my ES300 (2000). I chose a simpler way, where I directly connect a mini-jack into the audio line behind the HU (see attached image.) I burn an Audio-CD with one silence sound track of about 18 minute. Play this CD in the CD changer, repeat the track, while using the AUX. Works great. The other 5 CD in the CD changer still working ok (w/o AUX input). I have some concerns, though. Since both CD L- and CD R- are connected to the Ground of Mini-Jack, I wonder if it will cause any damage in the long run. Also, the external audio signal from the AUX will run back to the CD changer (R+-L+-), not sure if this will be an issue or not. I've tried this way for about 2 hours and don't see any issue yet. The CD changer still working in normal operation.
Mini-Jack harness HU
Red (Right) --------------- Red (CD R+) - 2
White (Left) -------------- Black (CD L+) - 1
copper (Ground) ---------- White (CD L-) - 6 (5 in the attached image)
copper (Ground) ---------- Green (CD R-) - 7 (6 in the attached image)
(correction: Perhaps Red=CDL+ and Black=CDR+, so Right/Letf need to be swapped)
#389
#390
Fat Felix
you will loose some sound quality not using the preouts of the ipod or with a zune adapter (is zune allows that like the ipod does). i have it wired with a 1/8 plug and it sounds real good, just as good as my cd changer in my ears and those of everyone thats heard it so far.
I'm working on a 'automatic switch' but now i have it wired as puredrift said with a relay set up and switch, my switch is in the center console of my 99 gs300 with 'premium' sound (says premium on the radio head unit) i got my power from the 12volt plug that runs in to the center console
to get to the wires drop the glove box take out the CD changer then splice in. this whole deal only takes 10 minutes its such a great mod
on the cd changer plug used this and it all worked nicely
Black___CDR+
Red_____CDL+
White___CDR-
Green___CDL-
Black___CDR+
Red_____CDL+
White___CDR-
Green___CDL-
