How To: Build and Hardwire an Auxillary Input to OEM Stereo
#421
Hey Awesome work PureDrifter!!!! im going to do this to my 93 gs 300 with a nak and i looked thu all 29 pages on this post and i cant find the 4 wire pin outs on the cd changer in the rear for a 1st gen gs. Unless its the same as a 1st gen ls. is there any1 that has this info i would really appreciate it.
for a GS 1st gen, the four wires at the cd changer in the rear which plug and wire nums/ colors please Thank you
signal____color______pin #
CDR+______?________?
CDL+______?________?
CDR-______?________?
CDL-______?________?
Thanks Again Everyone
#423
Radio 14 Pin Plug
CDR+___Blk___?______C1__?
CDL+____Red__?___C2_____?
CDR-__Wht____?_____C7___?
CDL-___Green___?____C8____?
CD Changer 10 Pin Plug
CDR+ BLK Pin A1
CDL+ RED Pin A2
CDR- WHT Pin A5
CDL- GRN Pin A6
#424
Thanks
Hey joebob1 Thanks alot im going to be doing this mod soon and thanks PureDrifter for your R&D Keep up the good work alot of people here now have music Clearer and Cleaner. you have made alot of people Happy
#425
Hey PureDrifter, can I hardwire into the tape part of the radio. Do you know where I need to solder. I want to try it but I want to know what I should be looking for before I open my radio.
#431
#432
Ok, so I am not new to dismantling cars and rebuilding them but I got a problem. I have an '01 GS3. My wire colors/positions didn't match what was posted. I followed the colors instead b/c the wires in a needed position looked more like a ground strap... I am testing it and getting sound out of the right side only and the volume control on the phone affects the volume level on the car? Any help or ideas? BTW I am using my Crackberry and not an iPod, but I doubt that matters. The speaker phone it creates is pretty cool though. The switch works fine cd off and aux when it is on.
#433
#435
It is the non M/L stereo. The amp is mounted vertical to the lower right of the CDC. There is a 12 pin (black) and 8 pin (orange) and two white 8 or so pin connectors below. I attached a pic of it (the back) and the order of the wires hopefully that helps. I also noticed the cd bleeding through with the phone unplugged and the volume at max, but I assume that is from the wiring issue.
Pink Black Red
Purple white blue gray green
Pink Black Red
