How To: Build and Hardwire an Auxillary Input to OEM Stereo
#529
Well it's a nak cd changer so it's plugs directly into the head unit not the amp and there's two separate blue plug harnesses that come from it to the head unit. So I don't know if it's even possible at this point so I just removed everything and wired everything back the way it was for now till I can figure out if it possible.
Can u do me a huge favor and circle or highlight which wires I should have intercepted?
#532
OK I got it to work but the changer is bleeding through when I press the switch and my friend works as a installer for Bestbuy and he told me that the reason its bleed through is because of a data wire that the changer has that plugs in to the headunit by itself. The one that is black and is label B(*2), he says that the Nakamichi changer for the 99-01 has the data wire and that 97-01 that has Pioneer radio does not have that data wire.
#533
mine is giving me a crazy amount of problems, first i got it to work but the volume was REALLY low ( itouch 1st gen) i turned both volumes all the way up on the itouch and the radio and i could barely hear what they where saying. Then it froze ( i have a 98 gs300 with navi and the 6 disk in the dash) when i tried to start it back up it was stuck at the LEXUS screen and would not do anything. Then i restarted and started a few times ( around 20) then it started working again. I tried to figure out the volume but i couldent, I tried switching around the r+ and L+ ( on the rca) but nothing, i rewired it but nothing. All while it froze on me about 5 times. Now when i try there is just a white screen and the car wont start ( battery is drained). I am tapping from the cd changer it self. I decided to tap from the amp itself but i cant get the radio to work now. Any ideas guys/girls?
also, in the diagram it says 30 goes to the amp but in the pics 30 goes to the clip
****** Fixed, when i did it with the amp it worked and the volume wasent low. But i did have the bleeding from the cd changer so i just cut the speaker wires and taped them up from the cd changer
#535
I've read around and it does seem that the CD player does use some sort of SPDIF (Digital coax) audio signal.
If the bleed through is a problem, we may have to use a 0-bit cd track as well.
Otherwise, I may rip mine open and see how hard it is to tap into the Tape signal. I know I would never use it.
#536
I have a 2002 GS300 with an Ipod hookup in the console. My question is how do you change the source to play the ipod? (Mark Levinison w/ Navi)
Thanks in advance for any help!!
Mojo
Mojo
#537
Props to PureDrifter for ths awesome DIY write up! Looking forward to getting it done this weekend. One question though, by using a SPDT rocker switch (on-off-on) can I totally cut the power off to the CD player/changer to prevent noise bleed while using my iPhone/iTouch?
Thanks guys!
Thanks guys!
#539
Did the install yesterday on my 2GS (Pioneer HU w/changer) and it works great! I bought the dock cable with the charging capability and that works too! Two question though about the noise bleed and volume level.
When I switch over to the AUX without the iPhone connected I hear the CD. Once I connect my iPhone to it I don't hear it anymore. Also the volume level is different from the AUX compared to the CD. Are these issues normal? Thanks again for DIY tutorial PureDrifter!
#540
I am experiencing same noise bleeding and volume level difference (lower when AUX is on) and wondering if these are normal or did I not wired correctly.
HardParkin, May I ask where you get dock cable for iphone with the charging capability? because my dock cable works (one with 3.5mm and USB) however it does not charged at all
