How To: Build and Hardwire an Auxillary Input to OEM Stereo
#661
Hey guys.
I was just wondering how this would go ?
I want to cut-off the CD changer completely and go MP3 only
https://www.clublexus.com/forums/lex...agram-aux.html
Will this work ?
It's a pretty crappy diagram sorry
Will this work ?
#662
Why must there be a CD player present for this to work? What if one were to wire an ipod dock directly to an orange plug, unplug the CD player harness from the amp and plug in the new ipod harness. Obviously the CD player would not be connected but would the ipod work? If not, there must be other signals present in the original orange CD harness other than the CD output alone.
Hey guys.
Will this work ?
Will this work ?
#666
" you can tap into the 4 audio (cd) wires from the disc changer then push CD and its not gonna recognize a disc but the audio should come through.
I have no dics in my cd changer and it plays crystal clear....."
So, if tap the wires, solder then heat-shrink tube it, and place a blank disc inside and switch it to CD , it will play the signal from the RCA cables ?
#667
Thanks PureDrifter. That makes sense. I think you answered my question with the "tx" lines. So you still need the "tx" data signal. I read in other threads that state that you must put a blank (or upside down) cd in cd players. Now I see why.
#668
I just completed this mod and it works perfectly. Thank you very much PureDrifter.
I ended up connecting a 3.5mm input instead of RCA inputs and located the switch and 3.5mm input inside my console. The relays are located under my console and I connected in behind the head unit instead of the CD Changer. I have a 98 GS400 w/ NAK.
Here is a pic of my install inside the lower portion of the center console:
Thanks again PD!
Thanks again PD!
#671
just a quick heads up for those that don't know, but http://www.gromaudio.com/ has plug and play solutions for this that are decently priced and allow control through the OEM radio in most situations even... there is aux input, ipod input and even usb stick input available for most cars...
mine works awesome on my IS300...
#673
#675
however for anything not covered, this is the fastest+easiest+cheapest way to quality sound
Nice install AZGS4
