How To: Build and Hardwire an Auxillary Input to OEM Stereo
Old 07-26-07, 12:32 PM
  #91
PureDrifter
BahHumBug
PureDrifter's Avatar
sorry for the leave of absence guys, ive been busy as hell lately and just havent had the time to put into my electronics stuff.
Originally Posted by strongsail
Puredrifter, could you post the pinouts for the 99 SC4 with Nak?
It's much easier to get to the harness at the amp/cd changer stack in the trunk than to pull the console trim and get to the back of the head unit, so colors and pin numbers at the cd or the amp would be great.
I know making the connection in the trunk means a longer signal run from the mp3 player in the center console, but it's easy to pull power and shielded audio cable to the trunk.
il get those pinouts to you asa i can
Originally Posted by Coco-bun
I might be asking too much but could someone draw me a wiring diagram for this?? and where should the switch between the RCA/CD Change go?? Somewhere between the CD changer and relay I would imagine...
off to frys for parts .
il try ot make up a wiring diagram in the next week or so as well and post it up.
Originally Posted by contentryd
pity this has to be done by bypassing the cd changer when my cd changer doesn't work...
can i bypass the TAPE player instead?
no, unless u feel like reverse engineering the entire lex/toy radio system from the inside-out.
Originally Posted by cartechpr
has anyone found direct factory connectors to avoid splicing?
Anyways... on the 98 i can tap under the right seat right? power and ground is ONLY for activating the relay right? other than that?? cable for the ipod?
Thanks
ehh, i could PROBABLY figure this out, but it wouldnt be cheap, id hafta request a factor harness repair kit from toyota. but if your REALLY interested i could prolly pull one together.
yes, power and ground is JUST for coil activation, a little note, use constant +12v, not switched.
Will the SDStoyo work for the nakamichi ls400?
I do have an amp under the seat.
Thanks
no idea, never used the product
Old 07-26-07, 10:58 PM
  #92
kit cat
kit cat's Avatar
dude, you're awesome! no rush though, get your work/study done first
and frys upped their prices on the SPDT relay...it was 6bucks each! Of course, being the cheapass I am, I didn't buy them
I've heard that Soundgates' SDStoyo does work, but its like 90bucks not including the cable to the iPod.
Old 07-26-07, 11:27 PM
  #93
PureDrifter
BahHumBug
ive got a few spares, il sell u a set of 4? pm me
Old 07-26-07, 11:38 PM
  #94
kit cat
kit cat's Avatar
thanks for the offer but I SUCK at soldering and I left my solder back in Tokyo so I was looking for something like what tnltracy did with the screw in type. I'm sure someone would love to buy it though.
Old 07-27-07, 06:09 AM
  #95
johnee78
johnee78's Avatar
Question
Puredrifter-Do you have a diagram for the first gen GS with pioneer??the changer is located in the trunk..
Old 08-25-07, 10:41 PM
  #96
lexesive
lexesive's Avatar
Hi Puredrifter
Have been reading this topic with great interest, so I went out and started pulling my car apart.
As Vstyle444 has a similar car I had a copy of his pin/colour codes but alas they don't match.
My car is a 2001 MY02 GS300 with sat nav, the 2001 model in Australia didn't have the Satnav but the 2002 does, my car was a change over model
Have attached pic of what I have, any chance of figuring it out for me.
Pin 5 at changer is perm 12V
Pin 10 " " " 12V accessories
Cheers
Geoff in Oz
Attached Thumbnails How To: Build and Hardwire an Auxillary Input to OEM Stereo-lexus-pins.jpg
Old 08-26-07, 02:04 AM
  #97
1996gs300
1996gs300's Avatar
does anyone have the pinout for a 96 GS300 with the nakamichi, the 12 disk changer is hosed and wiring the iphone sounds alot better than buying a new changer
Thank you
Neil
Old 09-01-07, 04:55 AM
  #98
PureDrifter
BahHumBug
Relay Array Wiring diagram is now in the first post
Old 09-01-07, 07:48 AM
  #99
Curry
Curry's Avatar
A big thank you to you pure drifter for your tips on getting this thing going.
I ended up using toggle switches to do the job since both electronics stores i went to did NOT have the damn relays...
But the switches worked just fine!
Old 09-01-07, 10:15 AM
  #100
Evil Twin
Evil Twin's Avatar
Thank you PureDrifter!
Any one do this on a 2nd gen GS400 w/Pioneer have pinouts to share?
Old 09-01-07, 01:54 PM
  #101
RTIS250
Yes. I drove the LFA.
RTIS250's Avatar
Ill pay someone to build this for me (98 GS400 w/ NAV). Im looking for a fairly easy plug and play system. Shoot me a PM
Old 09-01-07, 02:17 PM
  #102
PureDrifter
BahHumBug
id help but im all outta relays >.<
Ebay is ur friend when hunting for SPDT relays
Old 09-01-07, 02:34 PM
  #103
RTIS250
RTIS250's Avatar
Can i buy em, and have em shipped to ya?
Old 09-01-07, 05:02 PM
  #104
Stage3
Stage3's Avatar
This is interesting as all sin... I might have to print this out for my buddy that's a wiring guru and get him to wire this up. I can understand the basics of what's going on, and the pictures DEFINITELY help, but I'm a doofus when it comes to voltage and electronic "hacking." Knowing me, I would set up the system in such a way that it would fry everything in my car...
Excellent post!
Old 09-01-07, 06:17 PM
  #105
Evil Twin
Evil Twin's Avatar
I got mine at the local car audio place for about $3 a piece. Radio Shack wanted twice that!
Quick Reply: How To: Build and Hardwire an Auxillary Input to OEM Stereo
